Cisco Wireless controller and AP that support pass-point
Harvey Chen
Hi, we are trying to put together a test bed to experiment with Hot-Spot 2.0/PassPoint,
it would probably has one WLC and 2 APs for now, could someone please recommend
some modes? also if there is a list of Cisco WLC and Cisco APs that support passpoint?
thanks,
Arshad Safrulla
Most cost effective solution and my recommendation would be to go with 9800-CL(Compute and virtualization resources reqd) with Cat9105 AP's
Or used 3504 with Air1832 AP's
Please take note of the code running and read the release notes, as there could be snags in certain codes and certain features are supported after a certain release. So first finalize on the test cases, then plan accordingly.
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/Hotspot_057.html#pgfId-50895
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
