Cisco embedded wireless controller multicast enable
FCE
Community Member
Hi All ,
I have a Cisco AP model C9120AXI-E with embedded wireless controller v17.3.1 .
Does anyone know how I can enable multicast on cisco embedded wireless controller or is there any way to enable it?
Thanks for any help
12 Replies 12
Sandeep Choudhary
I think its similar to 9800 series WLC:
Navigate to:  Configuration > Services > Multicast
Dont forget to rate helpful posts
FCE
Community Member
unfortunately the option is not available in the menu
can you try from CLI, using this command:
AP(config)# wireless multicast
Thanks other idea ?
I have tried and is enabled but there is something missing and does not work
Arshad Safrulla
All the EWC AP's are in Flex mode, so you need to enable multicast routing at your switch level or upstream devices (Client is bridged to the AP).
multicast is enabled in my switch.
if did not understand correctly , do you have an instructions or  a youtube video for it ?
FCE
Community Member
I have tried different software versions also with 17.06.01b it does not work too
Yeah I'm pretty sure that EWC doesn't support the full multicast stack yet. There might be some undocumented features in the CLI, but I think only the stuff in my previously linked document is available.
FCE
Community Member
yes you're right
I could not find anything on the internet
Rich R
According to https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc87523896 EWC and WLC should have multicast feature parity for flexconnect so if it's not working it's a bug and you'll need a TAC case.
Regarding the GUI - make sure you login as admin - I've seen some menu's disappear when not using the admin user even though the user should have all/max priv (I think it's a bug but haven't bothered to look into it any deeper).
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
FCE
Community Member
Thank you for your search,
I am logged in as admin but I can't find the multicast option under service and in the CLI the the known commands don't work.
