Cisco Wireless controller WLC 5508 crash file
Pradeep H A
Hi all,
I have AIR-CT5508-500-K9 WLC running version 8.0.121.0 that has crashed & rebooted. Last reset reason shows as watchdog. The coredump generation feature has been disabled. So I dont have any logs to troubleshoot the issue. My questions are:
1. CSCsq49831 mentions that crashinfo file & coredump are different things on WLC. So how can I check for crashinfo files on WLC?
2. I did not find any commands to see the file system & its contents on a WLC other than the transfer upload/download commands. are there any?
3. I want to enable the coredump file generation feature. how to do it?
(xxxxxxxxxx) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.121.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... xxxxxxxxxxxxxxxxx
System Location..................................
System Contact...................................
System ObjectID..................................
Redundancy Mode.................................. Disabled
IP Address....................................... xxxxxxxxxxxx
IPv6 Address..................................... ::
Last Reset....................................... Watchdog reset
System Up Time................................... 3 days 4 hrs 8 mins 51 secs
System Timezone Location......................... (GMT -8:00) Pacific Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
(xxxxxxxxxxx) >show coredump sum
 Core Dump is disabled
Thanks a lot in advance!
Pradeep H A
Rasika Nayanajith
Hi Pradeep,
Under "Management -> Tech Support -> Controller Crash" can you see any crash information ?
In certain cases, crash info is not generated and WLC is silently crash & rebooted.
I would suggest you to upgrade to 8.0.140.0 release & see if these keep occurring.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn80mr4.html
Rasika
*** Pls rate all useful responses ***
