Cisco Wireless Devices regulatory domain
What is the Regulatory domain for cisco access points for Mauritania & Senegal ?
i checked cisco Wireless LAN Compliance Lookup, but it's not mentioned there, any other links for the same.
Leo Laohoo
For what AP model?
Catalyst IW6300 AC Heavy Duty Access Point
Nicolas Poirier
Level 4
Level 4
Mauritania and Senegal are not in the list of the country code available on Cisco WLCs.
Not easy to find, but you can check the authorized channels in the link below fron the Linux Kernel:
https://git.kernel.org/pub/scm/linux/kernel/git/sforshee/wireless-regdb.git/tree/db.txt?id=HEAD
The country code for Mauritania is MR and for Senegal is SN.
You can then try to find the Regulatory domain that allows only channels authorized on these countries thanks to this excellent document.
