Powering Mesh AP with power-injector AIR-PWRINJ6
mmisonne
Level 2
Level 2
I want to know if it is possible to provide power to a Mesh AP with a power injector like AIR-PWRINJ6, without connecting this to a switch port !
Because it is easier to use a Power injector than a Power adaptator is case there is no power outlet near the mesh AP
Michel Misonne
2 Accepted Solutions
Nicolas Poirier
Level 4
Level 4
Hello Michel,
Yes you can use a Power injector to power up the mesh access point.
You can find the supported powering options on the data sheet of the specific Access Point.
For example, below for the 1540 series:
5 Replies 5
Nicolas Poirier
Level 4
Level 4
Hello Michel,
Hi Nicolas,
Thanks for your reply !
Leo Laohoo
What is the exact model of AP you're planning to power up?
Hello Leo
AP model : 1815i
Power injector : AIR-PWRINJ6
It will work.
