CISCO WIRELESS DTLS LICENSE
ciscodinhnhat
Dear Experts,
I have now 40 Access Points ( Indoor  3800 and OutDoor 1560) and 2x WLC 9800.
If I want to encrypt management CWAPP and data wireless traffic with DTLS between WLC and Access Points ( Indoor or Outdoor), how many DTLS license do I have to buy   ?
Is it only 1 license will do or 40 licenses  ?
Thank you
Nicolas Poirier
Level 4
Level 4
The CAPWAP control tunnel (UDP/5246) is always encrypted with DTLS on the 9800.
For the CAPWAP Data tunnel (UDP/5247) you need to enable it on the AP join profile(s) you are using (cf sreenshot below).
Regarding the license, you need one per controller (LIC-C9800-DTLS-K9) and it is free (0 $).
Nicolas Poirier
Level 4
Level 4
Thank you
