I have installed a 9800-L-C appliance pair and established redundancy. I am facing couple of issues.
1. I am able to access the Active wlc through CLI but not GUI. It simply says "Wrong Credentials. Please Login again". I used the same credentials that I used for CLI access. TACACS server is ISE. I don't think we have seperate credentials for CLI and GUI in the new box.
2. I am unable to reload the WLC. I got the below error. Config-register value is correct 0x2102
WLC#reload
Reload to the ROM monitor only allowed from console line
unless the configuration register boot bits are non-zero.
Please advise.
Solved! Go to Solution.
ip http authentication local
worked immediately, Thanks!
worked for me also, thanks for the post
I have the same issue but "ip http authentication local" does not fix the issue. I set up an "admin" account during the initial set up and it doesn't work. I can't find out how to create a new account, via cli, that can be used to log into the web UI
Any help appreciated
i had different issue without being able to login HTTPS to the WLC (9800-L). once i applied the above command (NGWLC-9800L(config)#ip http secure-trustpoint CISCO_IDEVID_SUDI) it was fixed
Thanks that command helped to restore the WEB GUI.
ip http secure-server
