Cisco wireless mesh 1500 access points
stevegreen45
What range (if no obtructions are present) can the 1500 wireless mesh access point transmit in all directions
thomas.chen
Level 6
Level 6
This depends on various parameters inlcuding the type of antenna, the antenna hieght, power levels used on the Access Point, and cable loss. You can use the range calculator tool available on cisco.com to find out the maximum distance that the AP 1500 can reach provided you have the values for the above mentioned parameters.
