cisco wireless problem
pcfreak49
Level 7
Level 7
Hello I have Cisco wireless router 800 series the wireless module work such as must if I files of pc1 to pc2 do not send then become the wireless module reboot each time if I want files or move which can me help please copy
10 Replies 10
Nicolas Darchis
I'm not sure that many people understood your sentence because of the lack of punctuation. Maybe rephrasing would help getting you answers.
oké I have differently done my question
Leo Laohoo
Y'know what?  Maybe post the issue in your official native language and someone might (other than Google) can translate.
PS:  Maybe Cisco can make a language translator.
pcfreak49
Level 7
Level 7
Hallo ik heb een cisco wireless router, de wireless module werkt niet zoals het moet als ik iets wil verzenden of verplaatsen van pc1 naar pc2 draadloos dan restart de module altijd elke keer dat is toch niet normaal wie kan mijn helpen aub ?
mvg
I actually understand a bit of dutch but writing is much harder for me. I hope google translator will translate my words correctly 🙂
It's not normal that your router reboots everytime you transfer a file. Can you tell us what version of IOS you are running ? What is the exact model of your router ?
And can you also maybe collect the console output of the router when it reboots like that ?
thanks,
Nicolas
Het IOS 12.4 wire en voor wireless 15.0, het model dat ik heb is 891W
mvg
We would need more precise versions than that 🙂 there are a lot of different 12.4
And also the console output showing the crash would help.
Nicolas
de version 15.0 daar achter staat niets meer
version 15.0
mvg
"show version"
oke bedankt voor de tip Version 15.0(1)M2, voor wireless Version 12.4(21a) wire
mvg
