Cisco WISM Clustering Problem...
sujithr
I am Cisco WiSM consists of two Cisco 4404 controllers which is installed on the 6503 Switch. I am using Mac Address based authentication for clients to get connect.
When i am adding a new client's mac address to one controller, it is not reflecting to the Controller B. I have to manually make the entry in Controller B also.
Is this a problem related to Mobility Group configuration??
a-vazquez
Level 6
Level 6
To export the Mac filters from one controller to another, create a template using WCS and push it out to both controllers. Otherwise, you'd just have to refer to the mac-address list on one while implementing it on the other.
