Cisco WiSM Question
Jae_Robinson
Community Member
Using a Cisco WiSM Controller w/ version 4.1.181.0 to monitor/manage Rogues and Ad Hocs.
Wanting to dump the results into a database for management history -
If I use SNMP to retrieve the data - which MIB do I use...
Looking to get the table/results with
MAC address
SSID
Detecting Radios
what trap object ID do I use/set to capture?
is it possible to use a webget or wget to accomplish this as well?
didyap
Level 11
Level 11
Here is information about two OIDs which may help you :
Object ciscoLwappWlanMIB
OID 1.3.6.1.4.1.9.9.512
Object ciscoLwappApMIB
OID 1.3.6.1.4.1.9.9.513
Both OIDs belongs to the CISCO-LWAPP-AP-MIB.
Awesome!
Thanks - I believe that I am going to have to try and use an ssh solution to connect and get the table information on the Ad Hoc Rouge networks.
Sure with there was an easy way to deal with this as they are trying to set this up without having to provide an SNMP connection for those that are going to manage that data.
Thanks for the info.
