Cisco WISM2 HA problem
Mohamed Sayed
Level 4
Level 4
hi all
i have two cisco WISM2 in two 6500 configured as VSS
after I configured the HA from GUI, the two controllers rebooted together and i connect console to the primary one when it reach to starting the redundancy
it fail and appear to me
Dropping ARP packet since IP conflict is detected
and then the secondary controller is down and unreachable
please advice how can i solve this issue
thanks in advance
9 Replies 9
Sandeep Choudhary
You have a duplicate IP address in your network. You must find it out.
There is no otherway.
hi Sandeep Choudhary
thanks alot i found it and passed this step
but now I an stuck in other point, after configured the HA and while the two wisms reloading I found this log on the console of secondary wism:
Starting Redundancy: Starting Peer Search Timer of 120 seconds
Cannot open the file /mnt/application/ha/InheritedApCount.txt
Redundancy Link is down. Entering maintenance mode to avoid network conflict.
Entering maintenance mode...
ok
my IOS is 7.4.121
please advice ?
thanks in advance
1. is the cable connected and is the link LED active? What is the output from “show interfaces”?
2. Did you tried to reboot both WLC at same time??
Workaround:
Configure HA once again and reboot primary and after primary comes up then reboot secondary.(do not reboot at same time)
Dont forget to rate helpful posts
Hi Sandeep Choudhary,
1- the two wisms, each one in core 6500 and the physical connection between the two WISMs is the VSL link which of the VSS
does I need another physical link ?
2- i rebooted them at the same time and also i tried to reboot the primary controller first and after it come back up i rebooted the secondary but also failed ?
i would like to tell you something, the primary wism is activated permanent with 100 AP licesne and the secondary controller is activated with the evaluation license (1500 AP) which will be expired after time period, does this cause a problem in the HA ?
thanks in advance
1. To achieve HA between two Cisco WiSM2 platforms, the controllers should be deployed on a single chassis or on multiple chassis using a virtual switching system (VSS) and extending a redundancy VLAN between the multiple chassis.
2.Why you activated the evaluation license on WISM2 ? Noramally if you configured with HA and primary wlc is down then the HA-WLC  automatically share the configuration and the license for 90 days from the main WLC.
Hi Sandeep Choudhary ,
I didnot activate the evaluation license I found it activated
does this cause this problem of HA failure ?
I tried what you told me but the issue is still exist
now I have Cisco WLC1 is active and  WLC2 is mantanence mode
kindly find the logs of WLC during the reboot to activate HA as long as show redundancy summary from the two controllers:
init started: BusyBox v1.6.0 (2010-05-13 17:50:10 EDT) multi-call binary
starting pid 889, tty '': '/etc/init.d/rcS'
Enable memory base + limit on PLX for Octeon0 for BAR0+BAR1
Enable memory base + limit on PLX for Octeon1 for BAR0+BAR1
Change BAR2 setting for Octeon0
Change BAR2 setting for Octeon1
Set PLX switch prefetchable window to access BAR2 on Octeon0
Set PLX switch prefetchable window to access BAR2 on Octeon1
Set PLX switch MPS settings .............!!!!!!!
Detecting Hardware ...
set smp_affinity for irq 48
003f
Freeing __tmp_linux_reserved ...
Allocating named block ...
DP from CGE5.0 ...
DP from CGE5.0 ...
starting pid 1184, tty '/dev/ttyS0': '/usr/bin/gettyOrMwar'
Setting up ZVM
Exporting LD_LIBRARY_PATH
Cryptographic library self-test....passed!
XML config selected
Validating XML configuration
Read HA Config before validation
octeon_device_init: found 2 DPs
readCPUConfigData: cardid 0x6080001
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 7.4.121.0
Firmware Version FPGA 1.6, Env 0.0, USB console 2.2
Initializing OS Services: ok
Initializing Serial Services: ok
Initializing Network Services: ok
Initializing Licensing Services: ok
License daemon start initialization.....
License daemon running.....
Starting Statistics Service: ok
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Network Interface Management Services: ok
Starting System Services: ok
Starting FIPS Features: ok : Not enabled
Starting Fastpath Hardware Acceleration: ok
Starting Fastpath Console redirect : ok
Starting Fastpath DP Heartbeat : ok
Fastpath CPU0.00: Starting Fastpath Application. SDK-1.8.0, build 269. Flags-[DUTY CYCLE] : ok
Fastpath CPU0.00: Initializing last packet received queue. Num of cores(12)
Fastpath CPU0.00: Init MBUF size: 1856, Subsequent MBUF size: 2040
Fastpath CPU0.00: Core 0 Initialization and FIPS self-test: ok
Fastpath CPU0.00: Initializing Timer...
Fastpath CPU0.00: Initializing Timer...done.
Fastpath CPU0.00: Initializing NBAR AGING Timer...done.
Fastpath CPU0.01: Core 1 Initialization and FIPS self-test: ok
Fastpath CPU0.02: Core 2 Initialization and FIPS self-test: ok
Fastpath CPU0.03: Core 3 Initialization and FIPS self-test: ok
Fastpath CPU0.04: Core 4 Initialization and FIPS self-test: ok
Fastpath CPU0.05: Core 5 Initialization and FIPS self-test: ok
Fastpath CPU0.06: Core 6 Initialization and FIPS self-test: ok
Fastpath CPU0.07: Core 7 Initialization and FIPS self-test: ok
Fastpath CPU0.08: Core 8 Initialization and FIPS self-test: ok
Fastpath CPU0.09: Core 9 Initialization and FIPS self-test: ok
Fastpath CPU0.10: Core 10 Initialization and FIPS self-test: ok
Fastpath CPU0.11: Core 11 Initialization and FIPS self-test: ok
Fastpath CPU0.00: Received instruction to get link status
Fastpath CPU1.00: Starting Fastpath Application. SDK-1.8.0, build 269. Flags-[DUTY CYCLE] : ok
Fastpath CPU1.00: Initializing last packet received queue. Num of cores(12)
Fastpath CPU1.00: Init MBUF size: 1856, Subsequent MBUF size: 2040
Fastpath CPU1.00: Core 0 Initialization and FIPS self-test: ok
Fastpath CPU1.00: Initializing Timer...
Fastpath CPU1.00: Initializing Timer...done.
Fastpath CPU1.00: Initializing NBAR AGING Timer...done.
Fastpath CPU1.01: Core 1 Initialization and FIPS self-test: ok
Fastpath CPU1.02: Core 2 Initialization and FIPS self-test: ok
Fastpath CPU1.03: Core 3 Initialization and FIPS self-test: ok
Fastpath CPU1.00: Received instruction to get link status
Fastpath CPU1.04: Core 4 Initialization and FIPS self-test: ok
Fastpath CPU1.05: Core 5 Initialization and FIPS self-test: ok
Fastpath CPU1.06: Core 6 Initialization and FIPS self-test: ok
Fastpath CPU1.07: Core 7 Initialization and FIPS self-test: ok
Fastpath CPU1.08: Core 8 Initialization and FIPS self-test: ok
Fastpath CPU1.09: Core 9 Initialization and FIPS self-test: ok
Fastpath CPU1.10: Core 10 Initialization and FIPS self-test: ok
Fastpath CPU1.11: Core 11 Initialization and FIPS self-test: ok
Starting Switching Services: ok
Starting QoS Services: ok
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces: ok
Starting Client Troubleshooting Service: ok
Starting Management Frame Protection: ok
Starting Certificate Database: ok
Starting VPN Services: ok
Starting Licensing Services: ok
ok
Starting LWAPP: ok
Starting CAPWAP: ok
Starting LOCP: ok
Starting Security Services: ok
Starting Authentication Engine: ok
Starting Mobility Management: ok
Starting AVC Services: ok
Starting Virtual AP Services: ok
Starting AireWave Director: ok
Starting Network Time Services: ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
Starting RF Profiles: ok
Starting WLAN Control Protocol (WCP): ok
Starting Mesh Services:  ok
Starting TSM: ok
Starting CIDS Services: ok
Starting Ethernet-over-IP: ok
Starting DTLS server:  enabled in CAPWAP
Starting CleanAir: ok
Starting WIPS: ok
Starting SSHPM LSC PROV LIST: ok
Starting RRC Services: ok
Starting SXP Services: ok
Starting Alarm Services: ok
Starting FMC HS: ok
Starting IPv6 Services: ok
Starting Config Sync Manager : ok
Starting Hotspot Services: ok
Starting PMIP Services: ok
Starting Portal Server Services: ok
Starting mDNS Services: ok
Starting Management Services:
   Web Server:    CLI: ok
   Secure Web: ok
   License Agent: ok
(WiSM-slot22-1)
Enter User Name (or 'Recover-Config' this one-time only to reset configuration to factory defaults)
User:  admin
Password:*********
User:
User:admin
Password:*********
(WiSM-slot22-1) >
(WiSM-slot22-1) >
(WiSM-slot22-1) >
(WiSM-slot22-1) >show redundancy summary
 Redundancy Mode = SSO ENABLED
     Local State = MAINTENANCE
      Peer State = UNKNOWN - Communication Down
            Unit = Secondary - HA SKU
         Unit ID = 6C:20:56:2B:E6:60
Redundancy State = Non Redundant
    Mobility MAC = 6C:20:56:2B:E6:60
Maintenance Mode = Enabled
Maintenance cause= Negotiation Timeout
Redundancy Management IP Address................. 172.10.0.9
Peer Redundancy Management IP Address............ 172.10.0.11
Redundancy Port IP Address....................... 169.254.0.9
Peer Redundancy Port IP Address.................. 169.254.0.11
(WiSM-slot22-1) >
(WiSM-slot22-1) >
(WiSM-slot22-1) >
(WiSM-slot22-1) >sh
(WLC1) >show redundancy summary
     Local State = ACTIVE
            Unit = Primary
         Unit ID = 6C:20:56:2B:E5:A0
    Mobility MAC = 6C:20:56:2B:E5:A0
Redundancy Management IP Address................. 172.10.0.10
Peer Redundancy Management IP Address............ 172.10.0.12
Redundancy Port IP Address....................... 169.254.0.10
Peer Redundancy Port IP Address.................. 169.254.0.12
these are the coreVSS configuration of wism:
wism service-vlan 170
wism redundancy-vlan 169
wism switch 1 module 6 controller 1 allowed-vlan 1-999
wism switch 2 module 6 controller 1 allowed-vlan 1-999
wism switch 1 module 6 controller 1 native-vlan 500
wism switch 2 module 6 controller 1 native-vlan 500
wism switch 1 module 6 controller 1 qos trust dscp
wism switch 2 module 6 controller 1 qos trust dscp
please advice
thanks in advance
Can you please tell me which license you have on both WLCs.
Primary with enough AP license and secondary with HA-SKU or ??
alos check this link: http://www.my80211.com/storage/online-pdf-downloads/high-availability-dg-00.pdf
REgards
for the primary
(WLC1) >show license feature
Feature name        Enforcement   Evaluation  Clear Allowed  Enabled
base-ap-count       yes           yes         yes            yes
data_encryption     yes           no          yes            no
high_availability   yes           no          yes            no
(WLC1) >show license capacity
Licensed Feature    Max Count         Current Count     Remaining Count
AP Count            100               30                70
for the secondary:
(WiSM-slot22-1) >show license feature
This command is Not allowed on a HA-SKU Controller
(WiSM-slot22-1) >show license capacity
AP Count            1000              0                 1000
(WiSM-slot22-1) >
thanks in advance
IP address and License looks ok.
But there must be something wrong because WLC is in Maintanence mode.
Can you check the whole config again.
Sup720 and Wireless Services Module 2 (WiSM2) Basic Communication
http://me2learn.wordpress.com/2014/08/10/sup720-and-wireless-services-module-2-wism2-basic-communication/
Configure two WiSM2 for HA
