Cisco WLC 2504 with AIR-AP1131AG-A-K9
Gezimvatovci
Can you help me for some info regarding AIR-AP1131AG-A-K9.
I have a wlc 2504 but i don't know if the AIR-AP1131AG-A-K9 supported by 2504 wlc.
Can work this solution WLC 2504 with AIR-AP1131AG-A-K9 ???
if Yes ,  any guide.
Thanks a lot
Gezimv
Rasika Nayanajith
Refer this link. As long as you have 2504 with software version 8.0.x release you can use 1131 AP with it. Anything beyond software releases no longer support 1131 series.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
Rasika
*** Pls rate all useful responses ***
7 Replies 7
Rasika Nayanajith
Rasika
Rasika,
Can you help me I just change the ap from 1131 to 1602i are these supported by 2504 with version 8.0.
but I need to use this AP1602i also for voice and data.
so I have a 7926 phone so how can I configure the AP to us for VOIP phone and also for employee.
GV
All the configuration you have to do via 2504 WLC. You need to create two different SSID (or WLAN) on your controller.
Refer this document and make sure you have configured 2504 as per the given guidance
http://www.cisco.com/c/en/us/support/docs/wireless/2500-series-wireless-controllers/113034-2500-deploy-guide-00.html
Refer this video if you are new to 2504
Regarding WLAN creation for 7925 phone, please refer below vide
https://www.youtube.com/watch?v=aJ0ib3QJ0Vg
Rasika
Thanks a lot for answer,  but i don't know the controller not recognize the AP.
The controller 2504 is with version 8.0.100.0
AIR-SAP1602I-E-k9  with ios  "ap1g2-k9w7-mx.152-2.JB2/ap1g2-k9w7-mx.152-2.JB2"
I gave the IP of wlc2504 and the AP in BVI 1 , but when i go to check the controller on
Wireless> all AP's    and i don't see the AP on it.
Is it better to conect AP's on Wlc2504 or on switch give me an idea please
Gezimv
You got a autonomous AP image( "k9w7"). You have to convert this to lightweight in order to manage via a WLC.
Refer below post on how you can convert it to lightweight.
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Rasika
Thanks Rasika,
Is it better lightweight or to leave standalone for a small business.
The idea of standalone u need to configure one by one , and also one lightweight all are configure by controller or i'm wrong  ??
Gezim
Yes, that's right.
If this AP in a place where some other WLC managed AP, then it is better to change it to Lightweight.
Otherwise, I would leave it Autonomous and manage it as a standalone unit & configure it for basic wireless.
Rasika
