Cisco WLC 4425 console cable pinout
manishkr83
I have Cisco 4425 WLC and we have lost the console cable. Can any one share the pinout or any other way out to console into this device.
Manish Kumar
Hi Manish,
Typical RJ45 to DB9 cable should work. See shown below
https://www.ebay.com/p/Console-Cable-Rj45-to-Db9-CabConsole-72-3383-01-for-Cisco-Switch-Router/878379540?iid=331351632510
Refer this for more pinout details
http://www.cisco.com/c/en/us/support/docs/routers/7000-series-routers/12223-14.html
Rasika
*** Pls rate all useful responses ***
Hi Rasika,
Thanks for the reply but the problem is, WLC 4425 has DB9 pin Console interface and not RJ45 console interface.
