Cisco WLC 5500 ver.8 running config
rogers.frank
Does anybody have a complete "show-run" running config from a 5500 series controller, "sanitized" of course, they would care to post to share?
I need to create some config examples and do not have a piece of hardware to work with.
5 Replies 5
Scott Fella
Roger,
Typically you would use the exported config file to build a 'true' config.  The show run-config doesn't have the commands in order and will fail if you try to paste them in the same order.  Also, it depends on what exactly your trying to build... WLAN, Radius, SNMP, RF Profiles, etc.  These can be a pain in the rear to extract what you need.  Also, uploading a config from a different WLC can fail due to certain commands that need to be removed prior to uploading to a WLC.  Don't ask, but its dumb I think, I run into this everytime I edit a config to upload to another WLC.
-Scott
-Scott
I appreciate the input,  this is not intended to create a up-loadable config but to extract sections to put into a document to show what various settings look like in a running config. It is the same as copying a gig port section from a switch config, just to show what it looks like.
Thanks ...
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.01.13 14:15:58 =~=~=~=~=~=~=~=~=~=~=~=
config paging disable
Press Enter to continue...
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.130.2
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Viten_2504
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.162.20
Last Reset....................................... Software reset
System Up Time................................... 1 days 2 hrs 23 mins 10 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +27 C
External Temperature............................. +30 C
Fan Status....................................... 4100 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 50:06:04:CB:76:C0
Maximum number of APs supported.................. 25
AP Bundle Information
Primary AP Image    Size
ap1g2            9588
ap3g1            11308
ap3g2            11216
ap801            7172
ap802            8588
c1130            5072
c1140            9428
c1250            6964
c1520            8072
c602i            3744
Secondary AP Image    Size
ap1g2            9576
ap3g1            11296
ap3g2            11208
ap801            7164
ap802            8576
c1130            5072
c1140            9428
c1250            6964
c1520            8064
c602i            3736
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Strong Password Check Features:
     case-check ...........Enabled
     consecutive-check ....Enabled
     default-check .......Enabled
     username-check ......Enabled
Network Information
RF-Network Name............................. wnbu
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
Secure Web Mode SSL Protocol................ Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Enabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect  ................... Disable
Web Auth Captive-Bypass   .................. Disable
Web Auth Secure Web  ....................... Enable
Fast SSID Change ........................... Enabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
mDNS snooping............................... Disabled
mDNS Query Interval......................... 15 minutes
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       1000 Full  Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
AP Summary
Number of APs.................................... 3
Global AP User Name.............................. admin
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model              Ethernet MAC       Location          Port  Country  Priority
Viten_1142_2         2     AIR-LAP1142N-A-K9     00:22:bd:19:d5:80  default location  LAG      US       1
Viten_1142_1         2     AIR-LAP1142N-A-K9     00:22:90:90:df:6c  default location  LAG      US       1
Viten_2602_2         2     AIR-CAP2602I-A-K9     c0:67:af:58:e0:db  default location  LAG      US       1
AP Tcp-Mss-Adjust Info
AP Name              TCP State  MSS Size
Viten_1142_2         disabled   -
Viten_1142_1         disabled   -
Viten_2602_2         disabled   -
AP Location
Total Number of AP Groups........................ 0
Site Name........................................ default-group
Site Description................................. <none>
NAS-identifier................................... Viten_2504
AP Operating Class............................... Not-configured
RF Profile
2.4 GHz band..................................... <none>
5 GHz band....................................... <none>
WLAN ID          Interface          Network Admission Control          Radio Policy
 1               management           Disabled                          None
 4               management           Disabled                          None
RF Profile
Number of RF Profiles............................ 7
Out Of Box State................................. Disabled
RF Profile Name                    Band     Description                         11n-client-only
High-Client-Density-(802.11a)  5 GHz    <none>                      disable No
High-Client-Density-(802.11bg)  2.4 GHz  <none>                      disable No
Low-Client-Density-(802.11a)  5 GHz    <none>                      disable No
Low-Client-Density-(802.11bg)  2.4 GHz  <none>                      disable No
Typical-Client-Density(802.11bg)  2.4 GHz  <none>                      disable No
Typical-Client-Density-(802.11a)  5 GHz    <none>                      disable No
test                       5 GHz    <none>                      disable No
RF Profile name................................ High-Client-Density-(802.11a)
Description...................................... <none>
11n-client-only.................................. disabled
Radio policy..................................... 5 GHz
Transmit Power Threshold v1...................... -65 dBm
Transmit Power Threshold v2...................... -67 dBm
Min Transmit Power............................... 7 dBm
Max Transmit Power............................... 30 dBm
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
Max Clients...................................... 200
WLAN ID      maxClients
Client Trap Threshold............................ 50
Multicast Data Rate.............................. 0
Rx Sop Threshold................................. -78 dBm
Cca Threshold.................................... 0 dBm
Slot Admin State:................................ Enabled
Band Select Probe Response....................... Disabled
Band Select Cycle Count.......................... 2 cycles
Band Select Cycle Threshold...................... 200 milliseconds
Band Select Expire Suppression................... 20 seconds
Band Select Expire Dual Band..................... 60 seconds
Band Select Client Rssi.......................... -80 dBm
Load Balancing Denial............................ 3 count
Load Balancing Window............................ 5 clients
Coverage Data.................................... -80 dBm
Coverage Voice................................... -80 dBm
Coverage Exception............................... 3 clients
Coverage Level................................... 25 %
802.11n MCS Rates
    MCS-00 Rate.................................. enabled
    MCS-01 Rate.................................. enabled
    MCS-02 Rate.................................. enabled
    MCS-03 Rate.................................. enabled
    MCS-04 Rate.................................. enabled
    MCS-05 Rate.................................. enabled
    MCS-06 Rate.................................. enabled
    MCS-07 Rate.................................. enabled
    MCS-08 Rate.................................. enabled
    MCS-09 Rate.................................. enabled
    MCS-10 Rate.................................. enabled
    MCS-11 Rate.................................. enabled
    MCS-12 Rate.................................. enabled
    MCS-13 Rate.................................. enabled
    MCS-14 Rate.................................. enabled
    MCS-15 Rate.................................. enabled
    MCS-16 Rate.................................. enabled
    MCS-17 Rate.................................. enabled
    MCS-18 Rate.................................. enabled
    MCS-19 Rate.................................. enabled
    MCS-20 Rate.................................. enabled
    MCS-21 Rate.................................. enabled
    MCS-22 Rate.................................. enabled
    MCS-23 Rate.................................. enabled
RF Profile name................................ High-Client-Density-(802.11bg)
Radio policy..................................... 2.4 GHz
Transmit Power Threshold v1...................... -70 dBm
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Disabled
    802.11b/g 2M Rate............................ Disabled
    802.11b/g 5.5M Rate.......................... Disabled
    802.11b/g 11M Rate........................... Disabled
    802.11g 6M Rate.............................. Disabled
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Mandatory
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
WLAN ID      maxClients
Rx Sop Threshold................................. -82 dBm
802.11n MCS Rates
RF Profile name................................ Low-Client-Density-(802.11a)
Transmit Power Threshold v1...................... -60 dBm
Min Transmit Power............................... -10 dBm
WLAN ID      maxClients
Rx Sop Threshold................................. -80 dBm
Coverage Data.................................... -90 dBm
Coverage Voice................................... -90 dBm
802.11n MCS Rates
RF Profile name................................ Low-Client-Density-(802.11bg)
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
WLAN ID      maxClients
Rx Sop Threshold................................. -85 dBm
802.11n MCS Rates
RF Profile name................................ Typical-Client-Density(802.11bg)
WLAN ID      maxClients
Rx Sop Threshold................................. 0 dBm
802.11n MCS Rates
RF Profile name................................ Typical-Client-Density-(802.11a)
WLAN ID      maxClients
802.11n MCS Rates
RF Profile name................................ test
WLAN ID      maxClients
802.11n MCS Rates
AP Config
Cisco AP Identifier.............................. 3
Cisco AP Name.................................... Viten_1142_2
Country code..................................... US  - United States
Regulatory Domain allowed by Country............. 802.11bg:-A     802.11a:-A
AP Country code.................................. US  - United States
AP Regulatory Domain............................. -A
Switch Port Number .............................. 13
MAC Address...................................... 00:22:bd:19:d5:80
IP Address Configuration......................... DHCP
IP Address....................................... 192.168.162.110
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 192.168.162.1
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Enabled
Ssh State........................................ Disabled
Cisco AP Location................................ default location
Cisco AP Floor Label............................. 0
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................ Viten_2504
Primary Cisco Switch IP Address.................. 192.168.162.20
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... FlexConnect
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... system
S/W  Version .................................... 7.4.130.2
Boot  Version ................................... 12.4.18.0
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
Stats Collection Mode ........................... normal
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1142N-A-K9
AP Image......................................... C1140-K9W8-M
IOS Version...................................... 15.2(20150109:075323)$
Reset Button..................................... Enabled
AP Serial Number................................. FTX1332SBYY
AP Certificate Type.............................. Manufacture Installed
FlexConnect Vlan mode :.......................... Disabled
FlexConnect Group................................ Not a member of any group
Group VLAN ACL Mappings
FlexConnect Local-Split ACLs :
WLAN ID   PROFILE NAME                       ACL                                 TYPE
 Flexconnect Central-Dhcp Values :
WLAN ID   PROFILE NAME                         Central-Dhcp      DNS Override      Nat-Pat     Type
  4       test123                                  False             False          False      Wlan
FlexConnect Backup Auth Radius Servers :
 Primary Radius Server........................... Disabled
 Secondary Radius Server......................... Disabled
AP User Mode..................................... CUSTOMIZED
AP User Name..................................... admin
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 10.6.0.25
AP Up Time....................................... 1 days, 02 h 13 m 41 s
AP LWAPP Up Time................................. 1 days, 02 h 12 m 25 s
Join Date and Time............................... Mon Jan 12 12:55:07 2015
Join Taken Time.................................. 0 days, 00 h 01 m 15 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211n-2.4
    Administrative State ........................ ADMIN_DISABLED
    Operation State ............................. DOWN
    Operation State Down Cause................... Radio is exiting inline CDP low power mode holddown.
    Operation State Down Code.................... RADIO_RC_EXIT_LOW_PWR
    Radio Role .................................. ACCESS
    Radio Mode .................................. Remote
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 1
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... 00:23:eb:dc:c6:90
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      MCS Set
        MCS 0.................................... SUPPORTED
        MCS 1.................................... SUPPORTED
        MCS 2.................................... SUPPORTED
        MCS 3.................................... SUPPORTED
        MCS 4.................................... SUPPORTED
        MCS 5.................................... SUPPORTED
        MCS 6.................................... SUPPORTED
        MCS 7.................................... SUPPORTED
        MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
        MCS 10................................... SUPPORTED
        MCS 11................................... SUPPORTED
        MCS 12................................... SUPPORTED
        MCS 13................................... SUPPORTED
        MCS 14................................... SUPPORTED
        MCS 15................................... SUPPORTED
        MCS 16................................... DISABLED
        MCS 17................................... DISABLED
        MCS 18................................... DISABLED
        MCS 19................................... DISABLED
        MCS 20................................... DISABLED
        MCS 21................................... DISABLED
        MCS 22................................... DISABLED
        MCS 23................................... DISABLED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ US
      First Chan Num ............................ 1
      Number Of Channels ........................ 11
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 8
      Tx Power Level 1 .......................... 20 dBm
      Tx Power Level 2 .......................... 17 dBm
      Tx Power Level 3 .......................... 14 dBm
      Tx Power Level 4 .......................... 11 dBm
      Tx Power Level 5 .......................... 8 dBm
      Tx Power Level 6 .......................... 5 dBm
      Tx Power Level 7 .......................... 2 dBm
      Tx Power Level 8 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 6
      Tx Power Assigned By ...................... DTPC
    Phy OFDM parameters
      Current Channel ........................... 11
      Channel Assigned By ....................... DCA
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... AUTOMATIC
      Legacy Tx Beamforming ..................... DISABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
         A....................................... ENABLED
         B....................................... ENABLED
         C....................................... ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Client threshold........................... 12 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
    CleanAir Management Information
        CleanAir Capable......................... No
Attributes for Slot  1
    Radio Type................................... RADIO_TYPE_80211n-5
    Radio Subband................................ RADIO_SUBBAND_ALL
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
      Operation Rate Set
        6000 Kilo Bits........................... MANDATORY
        12000 Kilo Bits.......................... MANDATORY
        24000 Kilo Bits.......................... MANDATORY
      MCS Set
      First Chan Num ............................ 36
      Number Of Channels ........................ 21
    Tx Power
      Num Of Supported Power Levels ............. 6
      Tx Power Level 1 .......................... 14 dBm
      Tx Power Level 2 .......................... 11 dBm
      Tx Power Level 3 .......................... 8 dBm
      Tx Power Level 4 .......................... 5 dBm
      Tx Power Level 5 .......................... 2 dBm
      Tx Power Level 6 .......................... -1 dBm
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Current Channel ........................... 48
      Allowed Channel List....................... 36,40,44,48,52,56,60,64,100,
        ......................................... 104,108,112,116,132,136,140,
        ......................................... 149,153,157,161,165
      802.11n Antennas
      Coverage SNR threshold..................... 16 dB
Cisco AP Identifier.............................. 4
Cisco AP Name.................................... Viten_1142_1
MAC Address...................................... 00:22:90:90:df:6c
IP Address....................................... 192.168.162.117
Secondary Cisco Switch Name...................... Viten_5508_1
Secondary Cisco Switch IP Address................ 192.168.162.22
Administrative State ............................ ADMIN_DISABLED
AP Serial Number................................. FTX1308S2H3
AP Up Time....................................... 1 days, 02 h 13 m 28 s
AP LWAPP Up Time................................. 1 days, 02 h 12 m 12 s
Join Date and Time............................... Mon Jan 12 12:55:21 2015
      BSSID ..................................... 00:24:97:f1:21:f0
      Operation Rate Set
      MCS Set
    Tx Power
      Current Tx Power Level .................... 7
    Phy OFDM parameters
      Current Channel ........................... 6
      Legacy Tx Beamforming Configuration ....... CUSTOMIZED
      Legacy Tx Beamforming ..................... ENABLED
      802.11n Antennas
      Operation Rate Set
      MCS Set
    Tx Power
      Current Tx Power Level .................... 5
    Phy OFDM parameters
      Current Channel ........................... 161
      802.11n Antennas
Cisco AP Identifier.............................. 5
Cisco AP Name.................................... Viten_2602_2
MAC Address...................................... c0:67:af:58:e0:db
IP Address....................................... 192.168.162.122
Telnet State..................................... Disabled
AP Mode ......................................... Local
Logging syslog facility ......................... local7
Boot  Version ................................... 12.4.25.0
Mini IOS Version ................................ 7.5.1.73
AP Model......................................... AIR-CAP2602I-A-K9
AP Image......................................... C2600-K9W8-M
AP Serial Number................................. FTX1742J25V
AP Up Time....................................... 1 days, 02 h 10 m 52 s
AP LWAPP Up Time................................. 1 days, 02 h 09 m 25 s
Join Date and Time............................... Mon Jan 12 12:58:09 2015
Join Taken Time.................................. 0 days, 00 h 01 m 26 s
    Operation State Down Cause................... AP Admin State Change
    Operation State Down Code.................... AP_IF_TRAP_CONFIG_AP
    Radio Mode .................................. Local
      BSSID ..................................... e8:ed:f3:d9:6b:60
      Operation Rate Set
      MCS Set
        MCS 16................................... SUPPORTED
        MCS 17................................... SUPPORTED
        MCS 18................................... SUPPORTED
        MCS 19................................... SUPPORTED
        MCS 20................................... SUPPORTED
        MCS 21................................... SUPPORTED
        MCS 22................................... SUPPORTED
        MCS 23................................... SUPPORTED
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 22 dBm
      Tx Power Level 2 .......................... 19 dBm
      Tx Power Level 3 .......................... 16 dBm
      Tx Power Level 4 .......................... 13 dBm
      Tx Power Level 5 .......................... 10 dBm
      Tx Power Level 6 .......................... 7 dBm
      Tx Power Level 7 .......................... 4 dBm
    Phy OFDM parameters
      802.11n Antennas
         D....................................... ENABLED
    Radio Extended Configurations
      Beacon period.............................. 100 milliseconds
      Beacon range............................... AUTO
      Multicast buffer........................... AUTO
      Multicast data-rate........................ AUTO
      RX SOP threshold........................... AUTO
      CCA threshold.............................. AUTO
    Operation State Down Cause................... Radio interface has been shutdown.
    Operation State Down Code.................... RADIO_RC_IDB_SHUTDOWN
      Operation Rate Set
      MCS Set
    Tx Power
      Num Of Supported Power Levels ............. 4
      Tx Power Configuration .................... CUSTOMIZED
      Tx Power Assigned By ...................... User
    Phy OFDM parameters
      Configuration ............................. CUSTOMIZED
      Current Channel ........................... 153
      Channel Assigned By ....................... User
      802.11n Antennas
AP Airewave Director Configuration
AP Name.......................................... Viten_1142_2
  Slot ID........................................ 0
  Radio Type..................................... RADIO_TYPE_80211b/g
  Sub-band Type.................................. All
  Noise Information
    Noise Profile................................ PASSED
  Interference Information
    Interference Profile......................... PASSED
  Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 0 %
    Channel Utilization.......................... 0 %
    Attached Clients............................. 0 clients
  Coverage Information
    Coverage Profile............................. PASSED
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 0 clients
    RSSI  -68 dbm................................ 0 clients
    RSSI  -60 dbm................................ 0 clients
    RSSI  -52 dbm................................ 0 clients
  Client Signal To Noise Ratios
    SNR    0 dB.................................. 0 clients
    SNR    5 dB.................................. 0 clients
    SNR   10 dB.................................. 0 clients
    SNR   15 dB.................................. 0 clients
    SNR   20 dB.................................. 0 clients
    SNR   25 dB.................................. 0 clients
    SNR   30 dB.................................. 0 clients
    SNR   35 dB.................................. 0 clients
    SNR   40 dB.................................. 0 clients
    SNR   45 dB.................................. 0 clients
  Nearby APs
  Radar Information
  RF Parameter Recommendations
    Power Level.................................. 0
    RTS/CTS Threshold............................ 0
    Fragmentation Threshold...................... 0
    Antenna Pattern.............................. 0
  Persistent Interference Devices
  Class Type                 Channel  DC (%%)  RSSI (dBm)  Last Update Time
  All third party trademarks are the property of their respective owners.
  Slot ID........................................ 1
  Radio Type..................................... RADIO_TYPE_80211a
  Noise Information
    Channel 36...................................  -95 dBm
    Channel 40...................................  -94 dBm
    Channel 44...................................  -92 dBm
    Channel 48...................................  -97 dBm
    Channel 52...................................  -95 dBm
    Channel 56...................................  -96 dBm
    Channel 60...................................  -97 dBm
    Channel 64...................................  -94 dBm
    Channel 100..................................  -95 dBm
    Channel 104..................................  -92 dBm
    Channel 108..................................  -93 dBm
    Channel 112..................................  -93 dBm
    Channel 116..................................  -92 dBm
    Channel 132..................................  -89 dBm
    Channel 136..................................  -85 dBm
    Channel 140..................................  -87 dBm
    Channel 149..................................  -90 dBm
    Channel 153..................................  -89 dBm
    Channel 157..................................  -82 dBm
    Channel 161..................................  -76 dBm
    Channel 165..................................  -79 dBm
    Channel 36...................................  -57 dBm @  2 % busy
    Channel 40................................... -128 dBm @  0 % busy
    Channel 44................................... -128 dBm @  0 % busy
    Channel 48...................................  -69 dBm @  1 % busy
    Channel 52................................... -128 dBm @  0 % busy
    Channel 56................................... -128 dBm @  0 % busy
    Channel 60................................... -128 dBm @  0 % busy
    Channel 64................................... -128 dBm @  0 % busy
    Channel 100.................................. -128 dBm @  0 % busy
    Channel 104.................................. -128 dBm @  0 % busy
    Channel 108.................................. -128 dBm @  0 % busy
    Channel 112.................................. -128 dBm @  0 % busy
    Channel 116.................................. -128 dBm @  0 % busy
    Channel 132.................................. -128 dBm @  0 % busy
    Channel 136.................................. -128 dBm @  0 % busy
    Channel 140.................................. -128 dBm @  0 % busy
    Channel 149.................................. -128 dBm @  0 % busy
    Channel 153.................................. -128 dBm @  0 % busy
    Channel 157.................................. -128 dBm @  0 % busy
    Channel 161.................................. -128 dBm @  0 % busy
    Channel 165.................................. -128 dBm @  0 % busy
    Rogue Histogram (20/40_ABOVE/40_BELOW)
    Channel 36...................................  2/ 2/ 0
    Channel 40...................................  0/ 0/ 0
    Channel 44...................................  0/ 0/ 0
    Channel 48...................................  4/ 0/ 2
    Channel 52...................................  2/ 2/ 0
    Channel 56...................................  0/ 0/ 0
    Channel 60...................................  2/ 0/ 0
    Channel 64...................................  2/ 0/ 0
    Channel 100..................................  0/ 1/ 0
    Channel 104..................................  0/ 0/ 0
    Channel 108..................................  0/ 0/ 0
    Channel 112..................................  0/ 0/ 0
    Channel 116..................................  1/ 0/ 0
    Channel 132..................................  0/ 0/ 0
    Channel 136..................................  0/ 0/ 0
    Channel 140..................................  0/ 0/ 0
    Channel 149..................................  1/ 2/ 0
    Channel 153..................................  1/ 0/ 0
    Channel 157..................................  1/ 0/ 0
    Channel 161..................................  0/ 0/ 1
    Channel 165..................................  0/ 0/ 0
  Load Information
    Channel Utilization.......................... 11 %
  Nearby APs
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy............... unknown
    Previous Channel Average Energy.............. unknown
    Channel Change Count......................... 0
    Last Channel Change Time..................... Mon Jan 12 12:55:07 2015
    Recommended Best Channel..................... 48
    Power Level.................................. 1
    RTS/CTS Threshold............................ 2347
    Fragmentation Threshold...................... 2346
AP Name.......................................... Viten_1142_1
  Noise Information
  Load Information
  Nearby APs
  Radar Information
  Noise Information
  Load Information
  Nearby APs
  Radar Information
AP Name.......................................... Viten_2602_2
  Noise Information
  Load Information
  Nearby APs
  Radar Information
  Noise Information
  Load Information
  Nearby APs
  Radar Information
802.11a Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Supported
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
    MCS 16....................................... Supported
    MCS 17....................................... Supported
    MCS 18....................................... Supported
    MCS 19....................................... Supported
    MCS 20....................................... Supported
    MCS 21....................................... Supported
    MCS 22....................................... Supported
    MCS 23....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Enabled
        Priority 5............................... Enabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
        Aggregation scheduler.................... Enabled
            Realtime Timeout..................... 10
    A-MSDU Tx:
        Priority 1............................... Enabled
        Priority 2............................... Enabled
        Priority 3............................... Enabled
    Rifs Rx ..................................... Enabled
    Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC  Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice CAC Method ............................. Load-Based
   Voice tspec inactivity timeout................ Disabled
 CAC SIP-Voice configuration
   SIP based CAC ................................ Disabled
   SIP Codec Type ............................... CODEC_TYPE_G711
   SIP call bandwidth ........................... 64
   SIP call bandwith sample-size ................ 20
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
   Video load-based CAC mode..................... Disabled
   Video CAC Method ............................. Static
 CAC SIP-Video Configuration
   Best-effort AC - Admission control (ACM)...... Disabled
   Background AC - Admission control (ACM)....... Disabled
Maximum Number of Clients per AP Radio........... 200
802.11a Advanced Configuration
Member RRM Information
AP Name                          MAC Address       Admin    Oper        Channel    TxPower
Viten_1142_2                     00:23:eb:dc:c6:90 ENABLED  UP          48*        *1/6 (14 dBm)
Viten_1142_1                     00:24:97:f1:21:f0 ENABLED  DOWN        161*       *5/6 ( 2 dBm)
Viten_2602_2                     e8:ed:f3:d9:6b:60 ENABLED  DOWN        153         1/4 (14 dBm)
802.11a Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Mode for Mesh AP Backhaul...... disable
  802.11a Monitor Channels....................... Country channels
  802.11a RRM Neighbor Discover Type............. Transparent
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
  802.11a AP Neighbor Report Interval............ 180 seconds
  802.11a AP Interference Report Interval........ 120 seconds
Leader Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI..
  Transmit Power Assignment Leader............... Viten_2504 (192.168.162.20)
  Last Run....................................... 403 seconds ago
  TPC Mode....................................... Version 1
  TPCv2 Target RSSI.............................. -67 dBm
  TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
  TPCv2 SOP...................................... -85.0 dBm
  TPCv2 Default Client Ant Gain..................   0.0 dBi
  TPCv2 Path Loss Decay Factor...................   3.6
  TPCv2 Search Intensity......................... 10 Iterations
AP Name                          Channel    TxPower       Allowed Power Levels
Viten_1142_2                     *48        *1/6 (14 dBm) [14/11/8/5/2/-1/0/0]
Viten_1142_1                     *161       *5/6 ( 2 dBm) [14/11/8/5/2/-1/0/0]
Viten_2602_2                      153        1/4 (14 dBm) [14/11/8/5/0/0/0/0]
Coverage Hole Detection
  802.11a Coverage Hole Detection Mode........... Enabled
  802.11a Coverage Voice Packet Count............ 100 packets
  802.11a Coverage Voice Packet Percentage....... 50%
  802.11a Coverage Voice RSSI Threshold.......... -80 dBm
  802.11a Coverage Data Packet Count............. 50 packets
  802.11a Coverage Data Packet Percentage........ 50%
  802.11a Coverage Data RSSI Threshold........... -80 dBm
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
 Leader Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI..
  CleanAir Event-driven RRM option............... Disabled
  CleanAir Event-driven RRM sensitivity.......... Medium
  Channel Assignment Leader...................... Viten_2504 (192.168.162.20)
  DCA Sensitivity Level.......................... MEDIUM (15 dB)
  DCA 802.11n Channel Width...................... 20 MHz
  DCA Minimum Energy Limit....................... -95 dBm
  Channel Energy Levels
    Minimum...................................... unknown
    Average...................................... unknown
    Maximum...................................... unknown
  Channel Dwell Times
    Minimum...................................... 1 days, 02 h 12 m 35 s
    Average...................................... 1 days, 02 h 12 m 35 s
    Maximum...................................... 1 days, 02 h 12 m 35 s
  802.11a 5 GHz Auto-RF Channel List
    Allowed Channel List......................... 36,40,44,48,52,56,60,64,149,
                                                  153,157,161
    Unused Channel List.......................... 100,104,108,112,116,132,136,
                                                  140,165
  802.11a 4.9 GHz Auto-RF Channel List
    Unused Channel List.......................... 1,2,3,4,5,6,7,8,9,10,11,12,
                                                  13,14,15,16,17,18,19,20,21,
                                                  22,23,24,25,26
  DCA Outdoor AP option.......................... Disabled
802.11a Radio RF Grouping
  RF Group Name.................................. wnbu
  RF Protocol Version(MIN)....................... 30(30)
  RF Packet Header Version....................... 2
  Group Role(Mode)............................... LEADER(AUTO)
  Group State.................................... Idle
  Group Update Interval.......................... 300 seconds
  Group Leader................................... Viten_2504 (192.168.162.20)
  Group Member
  Last Run....................................... 161 seconds ago
802.11a CleanAir Configuration
Clean Air Solution............................... Disabled
Air Quality Settings:
    Air Quality Reporting........................ Enabled
    Air Quality Reporting Period (min)........... 15
    Air Quality Alarms........................... Enabled
      Air Quality Alarm Threshold................ 35
      Unclassified Interference.................. Disabled
      Unclassified Severity Threshold............ 20
Interference Device Settings:
    Interference Device Reporting................ Enabled
    Interference Device Types:
        TDD Transmitter.......................... Enabled
        Jammer................................... Enabled
        Continuous Transmitter................... Enabled
        DECT-like Phone.......................... Enabled
        Video Camera............................. Enabled
        WiFi Inverted............................ Enabled
        WiFi Invalid Channel..................... Enabled
        SuperAG.................................. Enabled
        Canopy................................... Enabled
        WiMax Mobile............................. Enabled
        WiMax Fixed.............................. Enabled
    Interference Device Alarms................... Enabled
    Interference Device Types Triggering Alarms:
        TDD Transmitter.......................... Disabled
        Continuous Transmitter................... Disabled
        DECT-like Phone.......................... Disabled
        Video Camera............................. Disabled
        SuperAG.................................. Disabled
        Canopy................................... Disabled
        WiMax Mobile............................. Disabled
        WiMax Fixed.............................. Disabled
Additional Clean Air Settings:
    CleanAir ED-RRM State........................ Disabled
    CleanAir ED-RRM Sensitivity.................. Medium
    CleanAir ED-RRM Custom Threshold............. 50
    CleanAir Persistent Devices state............ Disabled
    CleanAir Persistent Device Propagation....... Disabled
802.11a CleanAir AirQuality Summary
AQ = Air Quality
DFS = Dynamic Frequency Selection
AP Name            Channel Avg AQ Min AQ Interferers DFS
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11n Status:
    A-MPDU Tx:
    A-MSDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
   Voice CAC Method.............................. Load-Based
   SIP call bandwidth: .......................... 64
   SIP call bandwidth sample-size ............... 20
CAC SIP-Video configuration
Maximum Number of Clients per AP................. 200
802.11b Advanced Configuration
Viten_1142_2                     00:23:eb:dc:c6:90 DISABLED DOWN        11*        *6/8 ( 5 dBm)
Viten_1142_1                     00:24:97:f1:21:f0 ENABLED  DOWN        6*         *7/8 ( 2 dBm)
Viten_2602_2                     e8:ed:f3:d9:6b:60 ENABLED  DOWN        6*         *5/7 (10 dBm)
802.11b Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b RRM Neighbor Discovery Type............ Transparent
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  802.11b AP Neighbor Report Interval............ 180 seconds
  802.11b AP Interference Report Interval........ 120 seconds
  Last Run....................................... 145 seconds ago
Viten_1142_2                     *11        *6/8 ( 5 dBm) [20/17/14/11/8/5/2/-1]
Viten_1142_1                     *6         *7/8 ( 2 dBm) [20/17/14/11/8/5/2/-1]
Viten_2602_2                     *6         *5/7 (10 dBm) [22/19/16/13/10/7/4/0]
  802.11b Coverage Hole Detection Mode........... Enabled
  802.11b Coverage Voice Packet Count............ 100 packets
  802.11b Coverage Voice Packet Percentage....... 50%
  802.11b Coverage Voice RSSI Threshold.......... -80 dBm
  802.11b Coverage Data Packet Count............. 50 packets
  802.11b Coverage Data Packet Percentage........ 50%
  802.11b Coverage Data RSSI Threshold........... -80 dBm
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
  DCA Sensitivity Level: ...................... MEDIUM (10 dB)
  Channel Dwell Times
  802.11b Auto-RF Allowed Channel List........... 1,6,11
  Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
802.11b Radio RF Grouping
  Group Member
802.11b CleanAir Configuration
        Bluetooth Link........................... Enabled
        Microwave Oven........................... Enabled
        802.11 FH................................ Enabled
        Bluetooth Discovery...................... Enabled
        802.15.4................................. Enabled
        Microsoft Device......................... Enabled
        Bluetooth Link........................... Disabled
        Microwave Oven........................... Disabled
        802.11 FH................................ Disabled
        Bluetooth Discovery...................... Disabled
        802.15.4................................. Disabled
        Microsoft Device......................... Disabled
AQ = Air Quality
Mobility Configuration
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... wnbu
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x4e17
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 3
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
 MAC Address        IP Address       Group Name                        Multicast IP     Status
 00:27:0d:45:ad:00  192.168.162.22   wnbu                              0.0.0.0          Control and Data Path Down
 50:06:04:cb:76:c0  192.168.162.20   wnbu                              0.0.0.0          Up
 7c:ad:74:8d:81:00  192.168.162.25   wnbu                              0.0.0.0          Control and Data Path Down
Mobility Hash Configuration
 IP Address      Hash Key
Self Signed Certificate details
SSC Hash validation.............................. Enabled.
SSC device certificate not present.
Mobility Foreign Map Configuration
 WLAN ID     Foreign Mac Address     Interface
Probe request filtering..........................  Enabled
Probes fwd to controller per client per radio....  2
Probe request rate-limiting interval.............  500 msec
Aggregate Probe request interval.................  500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
Fastpath Packet Capture.......................... disable
Fastpath Fast Cache Control...................... enable
Fastpath Fast Testmode........................... 0x0
dot11-padding.................................... Disabled
Advanced Hotspot Commands
ANQP 4-way state................................. Disabled
GARP Broadcast state: ........................... Enabled
GAS request rate limit .......................... Disabled
ANQP comeback delay in TUs(TU=1024usec).......... 50
Location Configuration
RFID Tag data Collection......................... Enabled
RFID  timeout.................................... 1200 seconds
RFID mobility....................................
Interface Configuration
Interface Name................................... management
MAC Address...................................... 50:06:04:cb:76:cf
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.162.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 262
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (13)
Primary Physical Port............................ LAG (13)
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 192.168.150.25
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Interface Name................................... virtual
MAC Address...................................... 50:06:04:cb:76:c0
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
AP Manager....................................... No
Interface Name................................... vlan50
IP Address....................................... 50.50.50.5
IP Gateway....................................... 50.50.50.1
VLAN............................................. 50
NAS-Identifier................................... Viten_2504
Primary DHCP Server.............................. 192.168.162.20
Interface Group Configuration
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... 5508-2
Network Name (SSID).............................. 5508-2
Status........................................... Disabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
User Idle Threshold.............................. 0 Bytes
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream    Downstream
Average Data Rate................................   0          0
Average Realtime Data Rate.......................   0          0
Burst Data Rate..................................   0          0
Burst Realtime Data Rate.........................   0          0
Per-Client Rate Limits........................... Upstream    Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 192.168.162.30 1812
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
 Mobility Anchor List
 WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
WLAN Configuration
WLAN Identifier.................................. 4
Profile Name..................................... test123
Network Name (SSID).............................. test123
Status........................................... Enabled
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Address Assignment Required................. Disabled
Radius Servers
   Authentication................................ Global Servers
Security
      Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
      FT Over-The-DS mode........................ Disabled
   FlexConnect Local Switching................... Enabled
   FlexConnect Local Authentication.............. Enabled
ACL Configuration
ACL name: test
                       Source                         Destination                 Source Port  Dest Port
Index  Dir       IP Address/Netmask               IP Address/Netmask       Prot    Range       Range    DSCP  Action      Counter
     1 Any         0.0.0.0/0.0.0.0                 0.0.0.0/0.0.0.0           17    80-80       80-80     Any Permit           0
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. IP Address
Auth Call Station Id Type........................ AP's Mac Address:SSID
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. cisco-probe
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  MgmtTout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
1    NM    192.168.162.30    1812    Enabled   2     2         Disabled  Disabled - none/unknown/group-0/0 none/none
2    NM    192.168.162.31    1812    Enabled   2     2         Enabled   Disabled - none/unknown/group-0/0 none/none
Accounting Servers
TACACS Configuration
Idx  Server Address    Port    State     Tout  MgmtTout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
    EAP-FAST:
      Server key ................................ <hidden>
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f0000000000000000000000
      Authority Information ..................... Cisco A-ID
FlexConnect Group Summary
FlexConnect Group Summary: Count: 1
Group Name                # Aps
CPS                0
FlexConnect Group Detail
FlexConnect Group Name - CPS
Number of AP's in Group: 0
Efficient AP Image Upgrade ..... Disabled
Master-AP-Mac     Master-AP-Name                    Model      Manual
Group Radius Servers Settings:
 Primary       Unconfigured      Unconfigured
 Secondary     Unconfigured      Unconfigured
Group Radius AP Settings:
AP RADIUS server............ Disabled
EAP-FAST Auth............... Disabled
LEAP Auth................... Disabled
Server Key Auto Generated... No
Server Key..................     <hidden>
Authority ID................ 436973636f0000000000000000000000
Authority Info.............. Cisco A_ID
PAC Timeout................. 0
Multicast on Overridden interface config: Disabled
DHCP Broadcast Overridden interface config: Disabled
Number of User's in Group: 0
WLAN ID   SSID                            Central-Dhcp  Dns-Override  Nat-Pat
Route  Info
Number of Routes................................. 0
Destination Network          Netmask               Gateway
Peer Route  Info
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Qos Profile Info
Description...................................... For Voice Applications
Maximum Priority................................. voice
Unicast Default Priority......................... voice
Multicast Default Priority....................... voice
protocol......................................... none
Description...................................... For Video Applications
Maximum Priority................................. video
Unicast Default Priority......................... video
Multicast Default Priority....................... video
Description...................................... For Best Effort
Maximum Priority................................. besteffort
Unicast Default Priority......................... besteffort
Multicast Default Priority....................... besteffort
Description...................................... For Background
Maximum Priority................................. background
Unicast Default Priority......................... background
Multicast Default Priority....................... background
Mac Filter Info
MAC Address               WLAN Id          Description
6c:20:56:13:de:06         Any
78:da:6e:59:b6:80         Any
c0:67:af:58:e0:db         Any
Authorization List
Authorize MIC APs against Auth-list or AAA ...... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
  AP with Manufacturing Installed Certificate.... yes
  AP with Self-Signed Certificate................ no
  AP with Locally Significant Certificate........ no
Load Balancing Info
Aggressive Load Balancing........................ per WLAN enabling
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
Aggressive Load Balancing Uplink Threshold....... 50
Statistics (client-count based)
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
Statistics (uplink-usage based)
DHCP Info
No leases allocated.
Scope: vlan50
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 50.50.50.10
Pool End......................................... 50.50.50.20
Network.......................................... 50.50.50.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 50.50.50.1  0.0.0.0  0.0.0.0
DNS Domain.......................................
DNS.............................................. 0.0.0.0  0.0.0.0  0.0.0.0
Netbios Name Servers............................. 0.0.0.0  0.0.0.0  0.0.0.0
Pool Usage....................................... 0%
DHCP Opt-82 RID Format: <AP radio MAC address>
DHCP Opt-82 Format: binary
DHCP Proxy Behaviour:    enabled
DHCP Server IP Address:.......................... 192.168.150.25
  DHCP RX DISCOVER Count:........................ 0
  DHCP TX DISCOVER Count:........................ 0
  DHCP ACK Count:................................ 0
  DHCP REQUEST Count:............................ 0
  DHCP INFORM Count:............................. 0
  DHCP DECLINE Count:............................ 0
  DHCP RELEASE Count:............................ 0
  DHCP REPLY Count:.............................. 0
  DHCP OFFER Count:.............................. 0
  DHCP NAK Count:................................ 0
  Tx Fails:...................................... 0
  Last Rx Time:.................................. 0
  Last Tx Time:.................................. 0
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
cdp version v2
Country Channels Configuration
Configured Country............................. US  - United States
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory domain allowed by this country.
    802.11bg     :
    Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
 US (-A   ,-AB  ): A * * * * A * * * * A . . .
    802.11a      :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6 6 7
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5 9 3
 US (-A   ,-AB  ): . A . A . A . A A A A A * * * * * . . . * * * A A A A * . .
 4.9GHz 802.11a  :
    Channels     :                   1 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
 US (-A   ,-AB  ): * * * * * * * * * * * * * * * * * * * A * * * * * A
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Signature Policy
  Signature Processing........................... Enabled
Management Frame Protection
  Global Infrastructure MFP state................ DISABLED (*all infrastructure settings are overridden)
  Controller Time Source Valid................... False
                                    WLAN       Client
WLAN ID  WLAN Name                  Status     Protection
1        5508-2                     Disabled   Optional
4        test123                    Enabled    Optional
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... None
Custom Message................................... None
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
Logout-popup..................................... Enabled
External Web Authentication URL.................. None
Configuration Per Profile:
Core dump Configuration
 Core Dump is disabled
 Core Dump file on flash:
SW Version....................................... 7.4.121.0
Time Stamp....................................... Wed Dec 17 13:01:31 2014
File Size........................................ 8980283
File Name Suffix................................. _7.4.121.0_Viten_2504_1418821291.gz
Rogue AP Configuration
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
Rogue Detection Report Interval.................. 10
Rogue Detection Min Rssi......................... -128
Rogue Detection Transient Interval............... 0
Rogue Detection Client Num Thershold............. 0
Total Rogues(AP+Ad-hoc) supported................ 2000
Total Rogues classified.......................... 64
MAC Address        Classification     # APs # Clients Last Heard
00:24:97:ba:84:8f  Unclassified       1     0         Tue Jan 13 15:06:58 2015
08:cc:68:bd:98:ad  Unclassified       1     0         Tue Jan 13 15:03:59 2015
08:cc:68:bd:98:ae  Unclassified       1     0         Tue Jan 13 15:03:59 2015
08:cc:68:bd:98:af  Unclassified       1     0         Tue Jan 13 15:03:59 2015
1c:6a:7a:a9:13:1d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
1c:6a:7a:a9:13:1e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
1c:6a:7a:a9:13:1f  Unclassified       1     0         Tue Jan 13 14:55:03 2015
1c:6a:7a:b5:44:fd  Unclassified       1     0         Tue Jan 13 14:55:03 2015
1c:6a:7a:b5:44:fe  Unclassified       1     0         Tue Jan 13 15:06:58 2015
1c:6a:7a:b5:44:ff  Unclassified       1     0         Tue Jan 13 14:49:05 2015
20:aa:4b:8d:1f:50  Unclassified       1     0         Tue Jan 13 15:03:59 2015
24:b6:57:7b:c1:4c  Unclassified       1     0         Tue Jan 13 14:55:03 2015
24:b6:57:7b:c1:4d  Unclassified       1     0         Tue Jan 13 15:03:59 2015
24:b6:57:7b:c1:4e  Unclassified       1     0         Tue Jan 13 14:55:03 2015
24:b6:57:7b:c1:4f  Unclassified       1     0         Tue Jan 13 15:06:58 2015
24:b6:57:b4:62:2d  Unclassified       1     0         Tue Jan 13 15:03:59 2015
24:b6:57:b4:c3:dc  Unclassified       1     0         Tue Jan 13 14:55:03 2015
24:b6:57:b4:c3:dd  Unclassified       1     0         Tue Jan 13 14:55:03 2015
24:b6:57:b4:c3:de  Pending            1     0         Tue Jan 13 15:06:58 2015
24:b6:57:b4:c3:df  Unclassified       1     0         Tue Jan 13 15:06:58 2015
34:a8:4e:6a:3c:8d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
34:a8:4e:6a:3c:8e  Pending            1     0         Tue Jan 13 15:06:58 2015
34:a8:4e:6a:3c:8f  Unclassified       1     0         Tue Jan 13 14:58:01 2015
5c:a4:8a:b3:ea:11  Unclassified       1     0         Tue Jan 13 14:55:03 2015
5c:a4:8a:b3:ea:1f  Unclassified       1     0         Tue Jan 13 15:06:58 2015
68:86:a7:ca:3f:7e  Unclassified       1     0         Tue Jan 13 14:55:03 2015
68:86:a7:ca:3f:7f  Pending            1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:87:a8:2c  Unclassified       1     0         Tue Jan 13 15:03:59 2015
6c:9c:ed:87:a8:2d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:87:a8:2e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:87:b0:4d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:87:b0:4e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:87:b0:4f  Unclassified       1     1         Tue Jan 13 15:03:59 2015
6c:9c:ed:87:b0:ac  Unclassified       1     0         Tue Jan 13 14:52:04 2015
6c:9c:ed:87:b0:ad  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:87:b0:af  Unclassified       1     0         Tue Jan 13 15:03:59 2015
6c:9c:ed:eb:61:7d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:ec:9f:cc  Unclassified       1     0         Tue Jan 13 14:55:03 2015
6c:9c:ed:ec:9f:ce  Unclassified       1     0         Tue Jan 13 14:49:05 2015
6c:9c:ed:ec:9f:cf  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:ec:a0:3d  Unclassified       1     0         Tue Jan 13 15:03:59 2015
6c:9c:ed:ec:a0:3e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:ec:a0:3f  Unclassified       1     0         Tue Jan 13 14:58:01 2015
6c:9c:ed:ec:a9:7c  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:ec:a9:7d  Unclassified       1     0         Tue Jan 13 14:55:03 2015
6c:9c:ed:ec:a9:7e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
6c:9c:ed:ec:a9:7f  Unclassified       1     1         Tue Jan 13 15:03:59 2015
88:f0:77:bf:ca:4f  Unclassified       1     0         Tue Jan 13 15:06:58 2015
b4:a4:e3:1e:f4:6f  Unclassified       1     0         Tue Jan 13 15:03:59 2015
b4:e9:b0:a6:c8:4b  Unclassified       1     0         Tue Jan 13 14:55:03 2015
b4:e9:b0:a6:c8:4c  Pending            1     0         Tue Jan 13 15:06:58 2015
b4:e9:b0:a6:c8:4d  Unclassified       1     0         Tue Jan 13 14:58:01 2015
b4:e9:b0:a6:c8:4f  Unclassified       1     0         Tue Jan 13 14:49:05 2015
b8:38:61:0e:e7:8d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
b8:38:61:0e:e7:8e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
b8:38:61:0e:e7:8f  Unclassified       1     0         Tue Jan 13 14:55:03 2015
b8:38:61:9b:e5:b1  Unclassified       1     0         Tue Jan 13 14:55:03 2015
b8:38:61:9b:e5:bf  Unclassified       1     0         Tue Jan 13 14:58:01 2015
dc:7b:94:a5:02:e8  Unclassified       1     0         Tue Jan 13 15:06:58 2015
dc:7b:94:a5:02:e9  Unclassified       1     0         Tue Jan 13 15:06:58 2015
dc:7b:94:a5:02:ec  Unclassified       1     0         Tue Jan 13 15:06:58 2015
dc:7b:94:a5:02:ed  Unclassified       1     0         Tue Jan 13 15:06:58 2015
dc:7b:94:a5:02:ef  Unclassified       1     0         Tue Jan 13 14:55:03 2015
f4:0f:1b:99:4f:2d  Unclassified       1     0         Tue Jan 13 15:03:59 2015
f4:0f:1b:99:4f:2e  Unclassified       1     0         Tue Jan 13 15:06:58 2015
f4:0f:1b:99:4f:2f  Unclassified       1     0         Tue Jan 13 14:55:03 2015
f4:0f:1b:dd:dc:7d  Unclassified       1     0         Tue Jan 13 15:06:58 2015
f4:0f:1b:dd:dc:7f  Unclassified       1     0         Tue Jan 13 15:03:59 2015
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Total Rogues(Ad-Hoc+AP) supported ............... 2000
Total Ad-Hoc entries ............................ 0
Client MAC Address  Adhoc BSSID         State              # APs   Last Heard
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
Total Rogue Clients supported.................... 2500
Total Rogue Clients present...................... 2
MAC Address        State              # APs Last Heard
84:3a:4b:62:32:ec  Alert              1     Tue Jan 13 14:55:03 2015
84:3a:4b:93:c4:bc  Alert              1     Tue Jan 13 15:03:59 2015
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority         Rule Name                 Rule state Class Type   Notify   State    Match Hit Count
Media-Stream Configuration
Multicast-direct State........................... disable
Allowed WLANs....................................
Stream Name   Start IP                                End IP                                  Operation Status
URL..............................................
E-mail...........................................
Phone............................................
Note.............................................
State............................................ disable
2.4G Band Media-Stream Configuration
Multicast-direct................................. Enabled
Best Effort...................................... Disabled
Video Re-Direct.................................. Enabled
Max Allowed Streams Per Radio.................... Auto
Max Allowed Streams Per Client................... Auto
Max Video Bandwidth.............................. 0
Max Voice Bandwidth.............................. 75
Max Media Bandwidth.............................. 85
Min PHY Rate..................................... 6000
Max Retry Percentage............................. 80
5G Band Media-Stream Configuration
Number of Clients................................ 0
Client Mac         Stream Name  Stream Type  Radio WLAN  QoS    Status
WLC Voice Call Statistics
WLC Voice Call Statistics for 802.11b Radio
WMM TSPEC CAC Call Stats
  Total num of Calls in progress................. 0
  Num of Roam Calls in progress.................. 0
  Total Num of Calls Admitted.................... 0
  Total Num of Roam Calls Admitted............... 0
  Total Num of exp bw requests received.......... 0
  Total Num of exp bw requests Admitted.......... 0
  Total Num of Calls Rejected.................... 0
  Total Num of Roam Calls Rejected............... 0
  Num of Calls Rejected due to insufficent bw.... 0
  Num of Calls Rejected due to invalid params.... 0
  Num of Calls Rejected due to PHY rate.......... 0
  Num of Calls Rejected due to QoS policy........ 0
SIP CAC Call Stats
  Total Num of Calls in progress................. 0
  Total Num of Preferred Calls Received.......... 0
  Total Num of Preferred Calls Admitted.......... 0
  Total Num of Ongoing Preferred Calls........... 0
  Total Num of Calls Rejected(Insuff BW)......... 0
  Total Num of Roam Calls Rejected(Insuff BW).... 0
KTS based CAC Call Stats
WLC Voice Call Statistics for 802.11a Radio
SIP CAC Call Stats
WLC IPv6 Summary
Global Config............................... Enabled
Reachable-lifetime value.................... 300
Stale-lifetime value........................ 86400
Down-lifetime value......................... 30
RA Throttling............................... Disabled
RA Throttling allow at-least................ 1
RA Throttling allow at-most................. 1
RA Throttling max-through................... 10
RA Throttling throttle-period............... 600
RA Throttling interval-option............... passthrough
NS Multicast CacheMiss Forwarding........... Disabled
NA Multicast Forwarding..................... Enabled
Bonjour Service detailed
Bonjour profile detailed
Profile Name..................................... default-mdns-profile
Profile Id....................................... 1
No of Services................................... 0
No. Interfaces Attached.......................... 0
No. Interface Groups Attached.................... 0
No. Wlans Attached............................... 1
Wlan Ids......................................... 1
For my purposes,This is perfect ....thank you!!
gohussai
Level 4
Level 4
Frank it depends what your try to do for configure. Well you can do the following.
1- If you have any WLC 5500 and want that configuration to play with or want to use that on other WLC then:-
Use #copy running-config tftp://path to ftp server
After that you can import that configuration just change the order of running-config and tftp.
2- If you do not have any WLC just want to know general what and how to configure 5500 then :-
Check :-
http://www.cisco.com/c/en/us/support/wireless/5500-series-wireless-controllers/products-configuration-examples-list.html
OR  [This is very easy to follow as it have a bit scenario for 5500 series ]
https://araihan.wordpress.com/2010/04/30/complete-guide-to-build-a-cisco-wireless-infrastructure-using-cisco-wlc-5500-cisco-1142-ap-and-microsoft-radius-server/
Hope this help
