Cisco WLC 5508-SSL certificate for Management access
Prasan Venky
Level 3
Level 3
Dear Experts,
We got only chained certificate from our CA. But all doc says for Unchained cert for management access.
Is there any way to use the same for management GUI access...?
Can any one explain me about unchained certificate and its extension ...?
Thanks in advance...
KVS
Message was edited by: Prasan Venky
Scott Fella
Management from what I know needs to be unchained. Typically you would use a certificate from your company's root CA
-Scott
Yeah.. Even we tried with chained for that coz we got that oly form our CA. It was not working as expected.
What i need is to know about the unchained certificate..?
You would go through. The normal process of creating an unchained cert and upload that to the wlc.
-Scott
