Cisco WLC: Bypass Mac Filter with wpa psk
ivan.martin
Hello my name is Ivan
I have a WLC version 7.0.116.0 and 10 LAP registered in mode local. All of them are showing 4 SSID's. I need to work using to one SSID security in layer 2 with wpa psk +mac filter.
I already configure all the mac address in the interface of users (Different to Interface Management) and I enable the security mac filter in the wlan of users, but when one users of this wlan try to authenticate, the process by pass the mac filter and the user can authenticate without problems to the wlan.
When i look the context of the configuration i see the mac, ip adress description and the interface of users correctly. Morever in the wlan is mark with a check to enable the security mac.
I write on the wlc debug client (mac of client) and i can see his process of authentication pass without any problems.
Could you give me an advice to resolv this trouble.
Ivan
6 Replies 6
Justin Kurynny
Level 4
Level 4
Ivan,
I tested it on my lab controller and it works. Two questions for you:
  • Are you putting your MAC addresses in the MAC Filtering list?
  • Are you configuring your WLAN for MAC Filtering as indicated in the below screenshot?
Justin
Hi Justin, thanks for your answer
That´s correct. I did it on my wlc. The users can authenticate in the wlan without any problems, but bypass the mac filter.
I understand that in mode hreap can not support mac filter, but all the access points are in  mode local.
Any advice? Perhaps an issue?
Ivan.
Ivan,
Reading more closely, I think maybe the controller is behaving normally.
You say that you add the client to the MAC filtering list and you turn on MAC filtering for your WLAN. Then you say the client is allowed to authenticate. Am I getting that correctly? If so, that is what MAC filtering does--it allows all MAC addresses in the MAC filtering list to authenticate, i.e., the MAC filtering list is an allow list.
If you want to reject specific clients, then you need to put their MAC address in the Disabled Clients list (Security tab).
Does this help, or is it possible that I am still misunderstanding your issue?
Justin
Hello Justyn
Thats correct, but when i see the logs of authentication to the user, i see that the wlc can not show the method of mac filter, for example
user A, method layer 2 wpa psk + mac filter, i only see wpa psk  nothing else,
Morever, when  a users that does'nt exist in the list of mac address try to authenticate in the wlan, this users pass wiithout any problems.
It tell me that the user by pass the mac filter process, and i think that the wlc does'nt work very well
Thanks for your answer
Ivan
Ivan,
Ok, that makes sense. So yes, as far as I know, the logs are not super helpful when it comes to MAC filtering pass/fail, but you will find generic messages related to MAC filter events. Filtering for MAC is a layer 2 association-level event, so if a client does not pass, you will see an SNMP log message like:
Sun Mar 18 20:23:52 2012          Client Association Failure: MACAddress: Base Radio MAC: Slot: 0 User Name:unknown IP Addr: unknown Reason:Unspecified ReasonCode: 1
If they pass, then you will see:
Sun Mar 18 20:29:05 2012          Client Association: Client MAC: Base Radio MAC : Slot: 0 User Name:unknown IP Addr: unknown
If you are not seeing these messages, make sure you have SNMP trap controls turned on for Client association and association failure events:
I have done some more testing today and I am not running into the issues that you are seeing. In my setup, named clients can associate and unlisted clients are failing to associate. At this point I would recommend that you try upgrading your code to 7.0.220.0 or higher. My testing was done on 7.0.220.0.
Justin
Ivan,
Did you figure out the issue?
I discovered a command today that will allow you to show if MAC filtering is globally enabled on the WLC.
Try running this command on the CLI:
(wlc) >show advanced macfiltering
Authentication................................... enabled
Skip RADIUS (query only the local db)............ disabled
You can turn it on or off with
(wlc) >config advanced macfiltering ...
Maybe your configuration is different than above somehow?
Justin
