Cisco WLC Controllers in the same network
mikiNet
Hi All,
I have a one question. If it possible to run two Cisco WLC Controllers in the same subnet network ? I asking you because at this moment I have one WLC but it support only 25 AP and this licence pool has completely run out. I have additional Cisco WLC with 5 AP support. Can I put new WLC to the same network where old WLC working ?
Rasika Nayanajith
Yes, you can. Make sure you configure same mobility group name , rf-group name & virtual interface IP in both WLCs with mobility peering.
You can control which WLC is primary & which one is secondary for a given AP under High Availability tab of AP configuration.
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Rasika
Thanks !! :)
Best regards,
Bartek
I have additional question. So If I have Cisco WLC 2504 with support 25 AP, it is possible to increase number AP from 25 to 30 through buy additional licence for 5 AP and install this licence on Cisco WLC?
YES,
If you get 5 AP adder licences (something like L-LIC-CT2504-5A), you should be able to increase AP count from 25-30
Rasika
