Cisco WLC debug client command out help
rhallan
Level 2
Level 2
Can anyone please tell me what does this output from debug client means ?
IPv6_Msg_Task: Apr 17 13:21:53.884: [PA] 80:b6:55:d9:5d:c8 Link Local address fe80::82b6:55ff:fed9:5dc8 updated to mscb. Not Advancing pem state.Current state: mscb in apfMsMmInitial mobility state and client state APF_MS_STATE_A
Is this indicating a issue ?
Thanks.
5 Replies 5
Scott Fella
@rhallan when you capture your debug, use this tool to help you analyze that data.  This can help you understand the debug and show you any errors it detects.
https://cway.cisco.com/wireless-debug-analyzer/
-Scott
Yes I have that and use it.
This message is from the raw logs of debug client.
Does anyone know what exactly this message means ?
If the debug analyzer doesn't show the full output as an issue, I would not worry about it.  As far as knowing what each log is, if you can't find that when you Google the message, then you would have to reach out to TAC to tell you what that means.  I'm assuming that you already did that, so your next steps would be to ask TAC.  You can also just search MSCB to understand what that is along with PEM and APF_MS_STATE_A and try to make sense of that log.
-Scott
Take a read at this old post for ideas.
https://community.cisco.com/t5/wireless/mscb-still-in-init-state/td-p/1355744
-Scott
TAC said " just a generic messages for IPv6 not related to the authentication issue" but I though it still indicates a issue as it is indicating it is not advancing pem state. I am still concerned with the "Not"
