Cisco WLC interface groups and Meraki Wireless
SuperiorNS
I have been tasked with porting a current Cisco WLC solution that is EOL to a new Meraki solution. One issue I am running into is that the current Cisco solution has an interface group for many statically addressed devices on multiple VLANS attached to a single SSID. Does Meraki have a similar setup to this? I cannot find anything in their documentation that is like this.
Thanks....
https://community.cisco.com/t5/security-documents/how-to-integrate-meraki-networks-with-ise/ta-p/3618650
Note: Optionally, you may configure Per-User VLAN tagging in addition to the Group Policy assignment. ISE can tell the Cloud Management Platform which VLAN to assign to the user.  This method would allow you to further differentiate user groups and assign different access policies during authentication.
saravlak
Meraki works similar to Flex Cisco's native Flex solution and it doesn't support Interface-groups/bundling.
however, using AAA over-ride can enforce what client to place on what vlan.
Thanks for the response. The Flex like behavior I am familiar with , but the Interface groups had me stumped.
You mentioned AAA over ride , but of course they are not running AAA. Is there a Radius, or static configuration solution?
