Cisco WLC with two Differents Portal Web Authentication
ivan.martin
Hi my name is Ivan
I have a question:
I have a wlc 2504, with two profiles (ssid A and ssid B) with web authentication, and i would like to load two different customized portals web pages authentication totally different, to show two portals web to two diffferents profiles of users.
Is possible to do it ?
Thanks for your answer.
Regards.
Ivan
George Stefanick
Yes, indeed. Name the files differently from the first package. Perhaps make it "-2". Under the new SSID select the page with login-2 instead of your normal page.
Make sense?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Ravi Singh
Level 7
Level 7
From  the WLC version 4.2 and later a new feature is introduced wherein you  can have multiple cutomized login pages for Web authentication.George already told you how to achieve this. Sometimes web page does not load properly.
In order to have the web page load properly, it is not sufficient to set the web-authentication type as customized globally in the Security > Web Auth > Web login page. It must also be configured on a particular WLAN . In order to do this, complete these steps:
  1. Log into the GUI of the WLC.
  2. Click on the WLANs tab, and access the profile of the WLAN configured for Web-authentication.
  3. On the WLAN > Edit page, click the Security tab. Then, choose Layer 3.
  4. On this page, choose None as the Layer 3 Security.
  5. Check the Web Policy box, and choose the Authentication option.
  6. Check the Over-ride Global Config Enable box, choose Customized (Downloaded) as the Web Auth Type, and select the desired login page from theLogin Pagepull down menu. Click Apply.
