Clean Air in 1552 Mesh Topology
mmunozrosas
Is Clean Air supported on MAP and RAP 1552E at a 2,4 Ghz in a mesh toplogy.?????
at web cisco page: "cleanAir is supported on mesh AP backhaul at a 5-GHz radio of mesh"
Marco Muñoz
Scott Fella
Yes it is supported on the 1552 on both. The 5ghz though you have to hard set the channels so it will not switch channels
-Scott
Scott Fella
-Scott
