Clean Air Technology
praetoleiad
Level 3
Level 3
Good day guys!
I would like to ask if a Mobility Service Engine is really needed to make Clean Air functional on a Cisco 3500?
Thanks!
Leo Laohoo
No.  All you need is 7.X to run on the WLC.
One thing though ... For CleanAir to function optimally, it's recommended that you use 3500i/e exclusively.  You can't (you can but CleanAir won't run clean, excuse the pun) mix the 3500 with other non-CleanAir APs.
Leo Laohoo
Thanks Sir! the info was so helpful.
