CleanAir compatibility with AIR AP1832i
Rémi
Do you know if AIR-AP1832I-E-K9 is compatible with Clean Air feature ?
WLC version 8.5
Is there a compatibility matrix for Clea Air ?
Remi
Sandeep Choudhary
As per my knowledge CleanAir doent support on cisco 1832 AP.. but it does support SI.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-6/b_wlc_8_6_spectrum_intelligence_on_cisco_wave_2_aps.html
Dont forget to rate helpful posts
Leo Laohoo
What is the exact version of the WLC?
I am suspecting CleanAir has "crashed", hence the "NA".
NOTE:  Right-hands side says "CleanAir Oper Status" are all "DOWN"?
