CLI Commands Interface - IP Helpers
Oscar Castillo
Level 3
Level 3
Hi all,
I have a quick question. Is there a way that I can see which vlans/interfaces in the WLC are configured with IP helpers?
I hate the GUI, it's hard for me to work in GUI, I rather work in CLI.
(Controller) >show interface summary
Number of Interfaces.......................... 7
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management LAG 20 10.11.20.9 Static Yes No
redundancy-management LAG 20 0.0.0.0 Static No No
redundancy-port - untagged 0.0.0.0 Static No No
service-port N/A N/A 192.168.20.1 Static No No
virtual N/A N/A 1.1.1.1 Static No No
vlan012 LAG 8 10.11.8.4 Dynamic No No
vlan90 LAG 60 10.11.90.4 Dynamic No No
(Controller) >
Like below:
Router#sh run | inc (Vlan|helper)
interface Vlan4
ip helper-address 10.12.13.14
ip helper-address 10.15.16.1
interface Vlan8
interface Vlan60
interface Vlan100
interface Vlan101
Router#
Thank you in advance.
Rasika Nayanajith
On WLCs, you are not configuring any helper address.
As per above output, vlan 8 and 60 use for dynamic interfaces. If you look at L3 switch where those vlan's SVI defined, you will find any helper addreses configured under that
Rasika
*** Pls rate all useful responses ***
sremk
Hi Mate,
As Rasika mentioned, we don't have the concept of ip helper address, instead we use dhcp proxy. More details on dhcp proxy is mentioned in the below link.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0110.html
Also you can verify the dhcp proxy settings on command line of controller using the below.
>show interface detail <interface name>
Sreejith
