CLI show commands - AP Power (Autonomous)
LJ Gabrillo
Level 5
Level 5
Hi everyone,
I've been trying to find what the CLI show command for this UI:
AT: Software Tab
 CLICK: System Configuration
   SEE: System Power Settings
It displays the power settings,
quite useful in troubleshooting xD
Hope someone can help me
PS: I always configure my APs through CLI, but this verification command/UI keeps bugging me because I cant find its CLI command.
6 Replies 6
Stephen Rodriguez
try:
show controllers dot11radio 0|1
that should show you the current configured power and channel
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thank Steph,
But that isn't the one I am looking for
I am looking for Access Point  Power Supply DC or PoE verification.
As said, it can be found in UI:
 AT: Software Tab
the best I can come up with on that is to do this:
show logg | i %CDP_PD
this will parse the logging for the %CDP_PD message that calls out the power.
HTH,
Steve
HTH,
Steve
Thanks for the help Steve,
Well it looks like there is really no CLI command for that,
all log based xD
jqnombrefia
"show sysinfo" then the power supply will be shown:
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
laurencew
Is this what you are looking for?
(Controller) >grep include Power "sh ap config general AP_Name"
If it uses external power source you will get output similar to
(Controller) >grep include Power "sh ap config general Ap_Name"
Press any key to continue..
PoE Power Injector MAC Addr...................... 00:15:63:86:7d:bb
Power Type/Mode.................................. Power injector / Normal mode
There are 2 lines matching the pattern Power
(Contoller)
If using POE you should see something like this
(Controller) >grep include Power "sh ap config general AP_name"
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. PoE/Full Power
(Controller)
