Client can't connect to other SSID without forgeting Previous SSID
kashifglobal12
Dear All,
Hope you all are well. I have 2504 WLC having IOS 8.0.152. I have configured 5 SSID on WLC which are broadcasting Perfeclty fine. The problem is that when client connect to one ssid he is perfectly connecting but if he wants to connect to other SSID he must forget the previous one otherwise he is unable to connect.
Kindly Help.
Sandeep Choudhary
did you enable FAST-SSID change ? if not then enable it and try again.
Dont forget to rate helpful posts
Is there any error meassge when client connect to ssid from one to another?
I also agree Sandeep's advice,please try to enable fast-ssid change and try again.
(WLC) >config network fast-ssid-change enable
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
