Client Capture on the wireless
u8ys7pk
Visitor
I want to troubleshoot WLAN Client connection- and roaming-issues and need the packet capture filters to see all client relevant packets.
I tried
wlan src or dst <mac-addr>
but I see not all traffic
perhaps I ping the IP of this client and do not see the icmp packets.
I tried also
ip proto icmp
with and extra Meraki-AP on the same chanels but do not see the icmp packets
Best regards
Josef
aleabrahao
Meraki Community All-Star
What interface are you trying?
MR - Access points
The following options are available for a packet capture on the MR:
  • Access point: Select one or more access points to run the capture on.
  • Capture type: Select the interface to run the capture on;
    • wired - captures wired/uplink traffic from one or more RJ45 ports on the Access point.
    • wireless - captures wireless traffic
    • LAN - on some access point models, such as the MR30H, you can capture traffic from four LAN access ports.
  • Output: Select how the capture should be displayed; view output or download .pcap.
  • Ignore: Optionally ignore capturing broadcast/multicast traffic.
  • Filter expressions: Apply a capture filter.
The MR allows packet captures on its wired or wireless interface. Captures on the wireless interface are useful to troubleshoot issues when clients have connectivity issues to the access point. Captures from the wired interface an offer insight into the access point's interaction with the LAN.
Note that packet captures taken on the wired interface of access points running MR 27.0+ firmware will not display 802.1q VLAN tags.
Note: The default behavior of client packet captures is to capture traffic sourcing from the client. If a bi-directional (to and from) capture from a specific source and destination is required, use this filter wlan addr1 <MAC> or wlan addr2 <MAC>. Addr1 and Addr2 represents source and destination respectively.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Packet_Capture_Overview
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
danjns
Level 6
Level 6
Don't filter anything on the capture. Filter it later in wireshark
Please feel free to hit that kudos button
