03-02-2006 12:45 AM - edited 07-04-2021 11:43 AM
i need a wlan card (pcmcia) for a car which has wlan access outdoor. the cisco pcmcia card with external antenna is not availible any more. i also didnt found a client card from linksys where i can connect an external antennen outside the car (roof)
does anybody has an hint for me which card i can use with external antenna?
regards Bernhard
03-08-2006 06:55 AM
You can install the driver and client utilities from the Cisco Aironet Wireless LAN Client Adapters Drivers and Utilities CD or at Cisco.com. Two install routines are available: one for PCMCIA clients and one for PCI card clients. Refer this url for more information.
03-10-2006 09:25 AM
i think you didnt understand my question, i need a client solution where i have a notebook in the car and a wlan antenne on the roof of the car (outdoor) the ciso 802.11b lmc card isnt availibl anymore also from linksys there i no notebook card with external antenna.
