Client exclusion - Maximum 802.1 x-AAA failure attempts
RDavidov
Hello
Is it possible to change Maximum 802.1 x-AAA failure attempts values on WLC 9800 series?
The documentation only contains a description of this function, but does not indicate how to change this values
Excessive 802.1X Authentication Failures—Clients are excluded on the fourth 802.1X authentication attempt, after three consecutive failures.
For example by default Excessive 802.1X Authentication Failures is 3, can i change it to 5 or more ?
5 Replies 5
marce1000
 - Using some kind of 'brute force attack' on the issue with :
                   # show running-config all | inc aaa
   I notice :
                 >aaa authentication attempts login 3
               Change accordingly (with CLI in the running-config) , check if that works as intended
 M.
thanks, I'll try this option
pieterh
AFAIK client exclusion is handled at the authentication server
if this is Active Directory -> check there
The wlc exclusive list have it policy and this policy have defualt set for times authc failed are this what you ask for?
MHM
Yes. Is it possible to change the values in this policy so that the client gets on the exclusive list, for example, after 5 attempts ?
