Client Isolation - Cisco Catalyst 9800-CL Wireless Controller
smounche
Visitor
Greetings,
I am seeking assistance with configuring Client Isolation on a single SSID on a Cisco Catalyst 9800-CL Wireless Controller.
Basically, Users within the same VLAN must not be able to communicate with each other.
I have been informed that this can be achieved by connecting to the controller/AP via CLI and configuring an ACL.
I would greatly appreciate receiving detailed instructions on how to perform this configuration
Thank you.
7 Replies 7
Try under wlan
P2P block
MHM
I did it.
doesn't work. clients still able to see/communicate with each other
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-1/config-guide/b_wl_17_11_cg/wlans.html
  >...Configuring Advanced WLAN Properties (GUI)
  >...From the P2P Blocking Action drop-down list, choose the required value.
        (set to block)
  Also check this thread : https://community.cisco.com/t5/wireless/how-to-disable-wireless-client-communication-from-ap-flexconnect/td-p/4606630
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
check below guide :Peer-to-peer blocking
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
BB
smounche
Visitor
Thanks, everybody. @balaji.bandi @MHM Cisco World @Mark Elsen
but it seems that "Peer-to-peer blocking" not working fully
Quote;
Note:     In Flex mode with local switching, as traffic is not going through the controller, P2P blocking is applied only to traffic from clients connected to the same AP. It will not apply to inter-AP traffic. Similarly, in SD-Access mode, this setting really has no effect, as the client traffic is always sent to the fabric edge switch for policy to be applied.
And here is another Quote;
• Cisco controller with central switching clients supports peer-to-peer blocking for clients associated with different APs. However, this solution targets only clients connected to the same AP.
FlexConnect ACLs can be used as a workaround for this limitation.
- so the question is how do I set ACL
If that is your deployment sd-access look at the below document :
Native peer to peer blocking is NOT supported on the SDA-wireless.
An administrator would have to use the Cisco Trustsec policy to achieve the desired output.
https://www.cisco.com/c/dam/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/deploy-guide/cisco-dna-center-sd-access-wl-dg.pdf
BB
smounche
Visitor
I think my deployment is
Flex AP (local switching)
