On page 10-4 of the Cisco Wireless LAN Controller Configuration Guide (Software Version 4.0) under the section about Client and Network Load Balancing is the following note:
"Client load balancing works only for a single controller. It is not operate in a multi-controller
environment."
My question is as follows:
In a small environment where all access points are connected to a single primary controller and a second controller is only participating in the mobility and RF groups as a backup in the event of primary controller failure, will client load balancing work?
Thank you,
- Brad
