Client Losing connection
kenier
Community Member
We have a AIR-SAP2702E-A-K9  with system version ap3g2-k9w7-xx.153-3.JAB
Most of the client are losing their connections and they less than 200 feet from the AP, this is small office with 10 laptops with windows and Apple devices.
Here is the configuration for this AP.
version 15.3
no service pad
service password-encryption
hostname Office
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone -0500 -5 0
clock summer-time -0400 recurring
no ip source-route
no ip cef
ip domain name naranjo.com
ip name-server 8.8.8.8
ip name-server 4.2.2.2
dot11 syslog
dot11 ssid CIP2.4Ghz
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 132348071F0409232A292164657243
dot11 ssid CIP5.0Ghz
   vlan 1
   authentication open
   guest-mode
   wpa-psk ascii 7 10AC460C333F1F020D09237C747863
username
ip ssh authentication-retries 5
bridge irb
interface Dot11Radio0
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 ssid CIP2.4Ghz
 antenna gain 0
 stbc
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 ssid CIP5.0Ghz
 antenna gain 0
 peakdetect
 dfs band 3 block
 stbc
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss7 a2ss7 a3ss7
 channel dfs
 station-role root
interface Dot11Radio1.1
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.1
 bridge-group 1
interface GigabitEthernet1
 no ip address
 shutdown
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address f07f.062f.e124
 ip address 192.168.1.10 255.255.255.0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip default-gateway 192.168.1.1
ip forward-protocol nd
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community defaultCommunity RW
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
 access-class 111 in
line vty 0 4
 access-class 111 in
 length 0
 transport input all
sntp server us.pool.ntp.org
sntp broadcast client
end
Office#
Here is a part of the log.
1400 Mar 15 03:54:09.228 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
1401 Mar 15 03:54:08.848 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
1402 Mar 15 03:54:08.732 Information Interface Dot11Radio1, changed state to up
1403 Mar 15 03:54:03.612 Notification Line protocol on Interface Dot11Radio1, changed state to down
1404 Mar 15 03:54:02.272 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
1405 Mar 15 03:54:02.248 Information Error on Dot11Radio1 -
1406 Mar 15 03:49:02.924 Information Interface Dot11Radio1, Station 4c0b.be06.3a02 Associated KEY_MGMT[WPAv2 PSK]
1407 Mar 15 03:49:02.812 Information Interface Dot11Radio1, Deauthenticating Station 4c0b.be06.3a02 Reason: Sending station has left the BSS
1408 Mar 15 03:48:35.432 Information Interface Dot11Radio1, Station 4c8d.79d5.fe78 Reassociated KEY_MGMT[WPAv2 PSK]
1409 Mar 15 03:48:35.420 Information Interface Dot11Radio1, Deauthenticating Station 4c8d.79d5.fe78 Reason: Sending station has left the BSS
1410 Mar 15 03:48:35.392 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
1411 Mar 15 03:48:35.380 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
1412 Mar 15 03:48:33.244 Notification Line protocol on Interface Dot11Radio1, changed state to up
1413 Mar 15 03:48:32.244 Information Interface Dot11Radio1, changed state to up
1414 Mar 15 03:48:27.124 Notification Line protocol on Interface Dot11Radio1, changed state to down
1415 Mar 15 03:48:25.784 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
1416 Mar 15 03:48:25.760 Information Error on Dot11Radio1 -
1417 Mar 15 03:47:29.652 Information Interface Dot11Radio0, Station MAHA01 0024.d6af.112a Associated KEY_MGMT[WPAv2 PSK]
1418 Mar 15 03:47:28.992 Information Interface Dot11Radio1, Station 4c8d.79d5.fe78 Reassociated KEY_MGMT[WPAv2 PSK]
1419 Mar 15 03:47:28.980 Information Interface Dot11Radio1, Deauthenticating Station 4c8d.79d5.fe78 Reason: Sending station has left the BSS
1420 Mar 15 03:47:28.956 Debugging Station 0024.d6af.112a Authentication failed
1421 Mar 15 03:47:28.852 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
1422 Mar 15 03:47:28.840 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
1423 Mar 15 03:47:26.756 Notification Line protocol on Interface Dot11Radio1, changed state to up
1424 Mar 15 03:47:25.756 Information Interface Dot11Radio1, changed state to up
1425 Mar 15 03:47:20.632 Notification Line protocol on Interface Dot11Radio1, changed state to down
1426 Mar 15 03:47:19.292 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
1427 Mar 15 03:47:19.268 Information Error on Dot11Radio1 -
1428 Mar 15 03:27:36.208 Information Interface Dot11Radio0, Deauthenticating Station 0024.d6af.112a Reason: Sending station has left the BSS
1429 Mar 15 03:22:06.768 Information Interface Dot11Radio0, Station e0f5.c6df.3d5d Associated KEY_MGMT[WPAv2 PSK]
1430 Mar 15 03:15:36.260 Information Interface Dot11Radio0, Deauthenticating Station e0f5.c6df.3d5d Reason: Previous authentication no longer valid
1431 Mar 15 03:14:08.844 Information Interface Dot11Radio0, Station 142d.272c.3ad5 Reassociated KEY_MGMT[WPAv2 PSK]
1432 Mar 15 03:13:43.188 Information Interface Dot11Radio1, Deauthenticating Station 5c96.9d81.3223 Reason: Sending station has left the BSS
1433 Mar 15 03:13:36.760 Information Interface Dot11Radio1, Station 4c0b.be06.3a02 Associated KEY_MGMT[WPAv2 PSK]
1434 Mar 15 03:13:36.648 Information Interface Dot11Radio1, Deauthenticating Station 4c0b.be06.3a02 Reason: Sending station has left the BSS
1435 Mar 15 03:13:27.508 Information Interface Dot11Radio1, Station 20c9.d0b5.f9a7 Reassociated KEY_MGMT[WPAv2 PSK]
1436 Mar 15 03:13:27.496 Information Interface Dot11Radio1, Deauthenticating Station 20c9.d0b5.f9a7 Reason: Sending station has left the BSS
1437 Mar 15 03:13:27.420 Information Interface Dot11Radio1, Station 5c96.9d81.3223 Reassociated KEY_MGMT[WPAv2 PSK]
1438 Mar 15 03:13:27.408 Information Interface Dot11Radio1, Deauthenticating Station 5c96.9d81.3223 Reason: Sending station has left the BSS
1439 Mar 15 03:13:27.372 Information Interface Dot11Radio1, Station 4c8d.79d5.fe78 Reassociated KEY_MGMT[WPAv2 PSK]
1440 Mar 15 03:13:27.360 Information Interface Dot11Radio1, Deauthenticating Station 4c8d.79d5.fe78 Reason: Sending station has left the BSS
1441 Mar 15 03:13:25.248 Notification Line protocol on Interface Dot11Radio1, changed state to up
1442 Mar 15 03:13:24.248 Information Interface Dot11Radio1, changed state to up
1443 Mar 15 03:13:19.128 Notification Line protocol on Interface Dot11Radio1, changed state to down
1444 Mar 15 03:13:17.788 Notification Interface Dot11Radio1, changed state to resetPCI reset port 1
1445 Mar 15 03:13:17.764 Information Error on Dot11Radio1 -
0 Replies 0
