04-01-2021 01:14 AM - edited 07-05-2021 01:04 PM
Hi wireless pros,
it's me again with a Cat9800 question.
In release 17.3, the following feature was introduced:
Client Roaming Across Policy Profile
The controller allows seamless roaming between same WLAN associated with different policy profile.
The following command was introduced:
wireless client vlan-persistant
Although I don't have a current actual requirement to do seamless roaming between different policy profiles, I cannot guarantee, that this will pop up in the future.
So the question is:
If you have a pure 17.3+ deployment, it won't harm to add "wireless client vlan-persistant" into the default WLC configuration, right? As far as I understood the config guide, the command does not come with any drawbacks like a higher resource usage at the WLC.
Although completely different features, I compare this one with the "fast-ssid-change" feature in AireOS.
By day0 this feature was disabled by default (without knowing exactely why). So typically this is turned on nowadays, even if you don't have clients moving between different SSIDs... but why punishing them if they want to do it?
04-01-2021 02:17 AM
04-01-2021 02:37 AM
Like I said: "Although completely different features, I compare this one with the "fast-ssid-change" feature in AireOS."
I don't compare these two features from a functional point of view. More from a configuration standpoint:
=> The default value doesn't seem to make any sense (or I cannot think of any sense).
As of today I cannot think of any case why I would need this (fast roaming between different wireless profile policies). However, I don't see any drawback in activating "wireless client vlan-persistent", because obviously it only comes with advantages and no disadvantages. Or am I missing something?
04-01-2021 08:50 AM
