Client Servicing APs and wIPS Monitor Mode APs, and mixing AP models question???
rteel
Customer environment in one location is a mix of 3502i and 3602i LAPs. Customer is running wIPS Monitor Mode APs (not ELM). The answer to this question may be obvious, but wanted to get some feedback. In this environment would it be better to have the 3600 APs servicing clients with the 3500 APs doing wIPS, or having the 3500 servicing clients with the 3600 APs doing wIPS?  Or a mix, both 3500 and 3600 APs serving clients as well as other 3500 and 3600 APs performing in the wIPS Monitor Mode role?
Thank you
Scott Fella
It comes down to the performance required.  If it was me and I had a choice, I would use the 3602's for client access and the 3502's for wIPS.  Now does it really matter, not really.  Your client access just can ustilize the enhancement that the 3602's offer over the 3502's.  wIPS AP's don't really care and its client access that you should look at.  Heck, you can still put some of the other in local mode with wIPS sub mode to be hones.
-Scott
Scott Fella
-Scott
