Clients dropping connections
fb_webuser
Level 6
Level 6
Hello, I'm having a problem with my clients dropping the network connection constantly throughout the campus. I am using a Cisco 5508 controller and the APs are LAP1141N.
At first I thought it was a roaming issue but I tested with only 1 AP and the problem persisted, I can tell you that we don't have interference problems and that our old linksys APs used to work without flaws.
Posted by WebUser Carlos Valentín Guerrero
Viten Patel
i'd recommend opening a TAC case.
