Clients stuck on IP Learn
frederick.mercado
Odd functioning. We have some clients that have no issues with connecting and showing Run, while getting proper IP. Some clients just stagnate and drop. No MAC filtering, and clients all on same VLAN.
Here is a log of one of those...any ideas why? I saw a bug issues in the past on this, but we are running 17.3.3 on 9800 LC
I did see this bug report: Client stuck in IP learn state with FlexConnect local switching + central DHCP + DHCP required
CSCvs03177
2022/04/05 11:31:46.478545 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (ERR): MAC: a088.69dd.171f Triggering notification for IP learn timeout
2022/04/05 11:31:46.478558 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (ERR): a088.69dd.171f CLIENT_STAGE_TIMEOUT State = IP_LEARNING, WLAN profile = DATA2, Policy profile = DATA, AP name = LSL_Main_2
2022/04/05 11:31:46.478598 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_IPLEARN_CONNECT_TIMEOUT, fsm-state transition 00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|01|07|13|17|18|28|33|42|44|46|48|53|
2022/04/05 11:31:46.478700 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Delete mobile payload sent forbssid: 1006.ed3f.df8e WTP mac: 1006.ed3f.df80 slot id: 1
2022/04/05 11:31:46.478710 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_DELETE_IN_PROGRESS
2022/04/05 11:31:46.479032 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry deleted for ifid 0xa000000a
2022/04/05 11:31:46.479194 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (note): MAC: a088.69dd.171f Session manager disconnect event called, session label: 0x79000157
2022/04/05 11:31:46.480141 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DELETE_IN_PROGRESS -> S_CO_DELETED
2022/04/05 11:31:49.260776 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Association received. BSSID 1006.ed3f.df8e, WLAN DATA2, Slot 1 AP 1006.ed3f.df80, LSL_Main_2
2022/04/05 11:31:49.260909 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_INIT -> S_CO_ASSOCIATING
2022/04/05 11:31:49.261082 {wncd_x_R0-0}{1}: [dot11-validate] [16619]: (ERR): MAC: a088.69dd.171f Failed to validate dot11r pmkid. PMK cache not found
2022/04/05 11:31:49.261350 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Association success. AID 4, Roaming = False, WGB = False, 11r = True, 11w = False
2022/04/05 11:31:49.261449 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_ASSOCIATING -> S_CO_L2_AUTH_IN_PROGRESS
2022/04/05 11:31:49.261539 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x31 BSSID: MAC: 1006.ed3f.df8e capwap IFID: 0x90000013
2022/04/05 11:31:49.264577 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication initiated. method DOT1X, Policy VLAN 0,AAA override = 0 , NAC = 0
2022/04/05 11:31:49.264591 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (ERR): a088.69dd.171f wlan_profile Not Found : Device information attributes not populated
2022/04/05 11:31:49.266046 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (note): Authentication Success. Resolved Policy bitmap:15 for client a088.69dd.171f
2022/04/05 11:31:49.428035 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication Key Exchange Start. Resolved VLAN: 22, Audit Session id: C81F4A0A00000163FA916B20
2022/04/05 11:31:49.455190 {wncd_x_R0-0}{1}: [client-keymgmt] [16619]: (note): MAC: a088.69dd.171f EAP Key management successful. AKM:FT-DOT1X Cipher:CCMP WPA Version: WPA2
2022/04/05 11:31:49.455321 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Mobility discovery triggered. Client mode: Flex - Central Switching
2022/04/05 11:31:49.455324 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2022/04/05 11:31:49.455991 {wncd_x_R0-0}{1}: [mm-client] [16619]: (note): MAC: a088.69dd.171f Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_NONE, Client IFID: 0xa000000a, Client Role: Local PoA: 0x90000013 PoP: 0x0
2022/04/05 11:31:49.456147 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x32 BSSID: MAC: 1006.ed3f.df8e capwap IFID: 0x90000013
2022/04/05 11:31:49.456182 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2022/04/05 11:31:49.456273 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Client datapath entry params - ssid:DATA,slot_id:1 bssid ifid: 0x90000010, radio_ifid: 0x9000000b, wlan_ifid: 0xf0400005
2022/04/05 11:31:49.456487 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry created for ifid 0xa000000a
2022/04/05 11:31:49.456591 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2022/04/05 11:33:49.456986 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (ERR): MAC: a088.69dd.171f Triggering notification for IP learn timeout
2022/04/05 11:33:49.457001 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (ERR): a088.69dd.171f CLIENT_STAGE_TIMEOUT State = IP_LEARNING, WLAN profile = DATA2, Policy profile = DATA, AP name = LSL_Main_2
2022/04/05 11:33:49.457048 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_IPLEARN_CONNECT_TIMEOUT, fsm-state transition 00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|01|07|13|17|18|28|33|42|44|46|48|53|
2022/04/05 11:33:49.457172 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Delete mobile payload sent forbssid: 1006.ed3f.df8e WTP mac: 1006.ed3f.df80 slot id: 1
2022/04/05 11:33:49.457183 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_DELETE_IN_PROGRESS
2022/04/05 11:33:49.457512 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry deleted for ifid 0xa000000a
2022/04/05 11:33:49.457673 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (note): MAC: a088.69dd.171f Session manager disconnect event called, session label: 0xb000159
2022/04/05 11:33:49.458654 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DELETE_IN_PROGRESS -> S_CO_DELETED
2022/04/05 11:33:52.686276 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Association received. BSSID 1006.ed3f.df8e, WLAN DATA2, Slot 1 AP 1006.ed3f.df80, LSL_Main_2
2022/04/05 11:33:52.686421 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_INIT -> S_CO_ASSOCIATING
2022/04/05 11:33:52.686828 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Association success. AID 4, Roaming = False, WGB = False, 11r = False, 11w = False
2022/04/05 11:33:52.686922 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_ASSOCIATING -> S_CO_L2_AUTH_IN_PROGRESS
2022/04/05 11:33:52.687014 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x31 BSSID: MAC: 1006.ed3f.df8e capwap IFID: 0x90000013
2022/04/05 11:33:52.690321 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication initiated. method DOT1X, Policy VLAN 0,AAA override = 0 , NAC = 0
2022/04/05 11:33:52.690335 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (ERR): a088.69dd.171f wlan_profile Not Found : Device information attributes not populated
2022/04/05 11:33:52.691781 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (note): Authentication Success. Resolved Policy bitmap:15 for client a088.69dd.171f
2022/04/05 11:33:52.805667 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication Key Exchange Start. Resolved VLAN: 22, Audit Session id: C81F4A0A00000164FA934D42
2022/04/05 11:33:52.833115 {wncd_x_R0-0}{1}: [client-keymgmt] [16619]: (note): MAC: a088.69dd.171f EAP Key management successful. AKM:DOT1X Cipher:CCMP WPA Version: WPA2
2022/04/05 11:33:52.833248 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Mobility discovery triggered. Client mode: Flex - Central Switching
2022/04/05 11:33:52.833251 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2022/04/05 11:33:52.833952 {wncd_x_R0-0}{1}: [mm-client] [16619]: (note): MAC: a088.69dd.171f Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_NONE, Client IFID: 0xa000000a, Client Role: Local PoA: 0x90000013 PoP: 0x0
2022/04/05 11:33:52.834097 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x32 BSSID: MAC: 1006.ed3f.df8e capwap IFID: 0x90000013
2022/04/05 11:33:52.834146 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2022/04/05 11:33:52.834232 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Client datapath entry params - ssid:DATA,slot_id:1 bssid ifid: 0x90000010, radio_ifid: 0x9000000b, wlan_ifid: 0xf0400005
2022/04/05 11:33:52.834444 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry created for ifid 0xa000000a
2022/04/05 11:33:52.834561 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2022/04/05 11:35:52.834468 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (ERR): MAC: a088.69dd.171f Triggering notification for IP learn timeout
2022/04/05 11:35:52.834486 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (ERR): a088.69dd.171f CLIENT_STAGE_TIMEOUT State = IP_LEARNING, WLAN profile = DATA2, Policy profile = DATA, AP name = LSL_Main_2
2022/04/05 11:35:52.834533 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_IPLEARN_CONNECT_TIMEOUT, fsm-state transition 00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|01|07|13|17|18|28|33|42|44|46|48|53|
2022/04/05 11:35:52.834649 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Delete mobile payload sent forbssid: 1006.ed3f.df8e WTP mac: 1006.ed3f.df80 slot id: 1
2022/04/05 11:35:52.834659 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_DELETE_IN_PROGRESS
2022/04/05 11:35:52.835002 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry deleted for ifid 0xa000000a
2022/04/05 11:35:52.835176 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (note): MAC: a088.69dd.171f Session manager disconnect event called, session label: 0xbe00015a
2022/04/05 11:35:52.836140 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DELETE_IN_PROGRESS -> S_CO_DELETED
2022/04/05 11:35:55.774644 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Re-Association received. BSSID 1006.ed3f.1d6e, WLAN DATA2, Slot 1 AP 1006.ed3f.1d60, LSL_Main_1
2022/04/05 11:35:55.774774 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_INIT -> S_CO_ASSOCIATING
2022/04/05 11:35:55.775204 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Association success. AID 1, Roaming = False, WGB = False, 11r = False, 11w = False
2022/04/05 11:35:55.775301 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_ASSOCIATING -> S_CO_L2_AUTH_IN_PROGRESS
2022/04/05 11:35:55.775392 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x31 BSSID: MAC: 1006.ed3f.1d6e capwap IFID: 0x9000000a
2022/04/05 11:35:55.778546 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication initiated. method DOT1X, Policy VLAN 0,AAA override = 0 , NAC = 0
2022/04/05 11:35:55.778560 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (ERR): a088.69dd.171f wlan_profile Not Found : Device information attributes not populated
2022/04/05 11:35:55.780011 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (note): Authentication Success. Resolved Policy bitmap:15 for client a088.69dd.171f
2022/04/05 11:35:55.890765 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication Key Exchange Start. Resolved VLAN: 22, Audit Session id: C81F4A0A00000165FA952E12
2022/04/05 11:35:55.927324 {wncd_x_R0-0}{1}: [client-keymgmt] [16619]: (note): MAC: a088.69dd.171f EAP Key management successful. AKM:DOT1X Cipher:CCMP WPA Version: WPA2
2022/04/05 11:35:55.927452 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Mobility discovery triggered. Client mode: Flex - Central Switching
2022/04/05 11:35:55.927456 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2022/04/05 11:35:55.928152 {wncd_x_R0-0}{1}: [mm-client] [16619]: (note): MAC: a088.69dd.171f Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_NONE, Client IFID: 0xa000000a, Client Role: Local PoA: 0x9000000a PoP: 0x0
2022/04/05 11:35:55.928297 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x32 BSSID: MAC: 1006.ed3f.1d6e capwap IFID: 0x9000000a
2022/04/05 11:35:55.928335 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2022/04/05 11:35:55.928423 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Client datapath entry params - ssid:DATA,slot_id:1 bssid ifid: 0x90000007, radio_ifid: 0x90000002, wlan_ifid: 0xf0400005
2022/04/05 11:35:55.928634 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry created for ifid 0xa000000a
2022/04/05 11:35:55.928827 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
2022/04/05 11:37:55.928387 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (ERR): MAC: a088.69dd.171f Triggering notification for IP learn timeout
2022/04/05 11:37:55.928404 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (ERR): a088.69dd.171f CLIENT_STAGE_TIMEOUT State = IP_LEARNING, WLAN profile = DATA2, Policy profile = DATA, AP name = LSL_Main_1
2022/04/05 11:37:55.928543 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Client delete initiated. Reason: CO_CLIENT_DELETE_REASON_IPLEARN_CONNECT_TIMEOUT, fsm-state transition 00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|01|07|13|17|18|28|33|42|44|46|48|53|
2022/04/05 11:37:55.928655 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Delete mobile payload sent forbssid: 1006.ed3f.1d6e WTP mac: 1006.ed3f.1d60 slot id: 1
2022/04/05 11:37:55.928666 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_IP_LEARN_IN_PROGRESS -> S_CO_DELETE_IN_PROGRESS
2022/04/05 11:37:55.929003 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry deleted for ifid 0xa000000a
2022/04/05 11:37:55.929172 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (note): MAC: a088.69dd.171f Session manager disconnect event called, session label: 0x8800015b
2022/04/05 11:37:55.930152 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DELETE_IN_PROGRESS -> S_CO_DELETED
2022/04/05 11:38:06.456174 {wncd_x_R0-0}{1}: [client-iplearn] [16619]: (ERR): MAC: a088.69dd.171f Iplearn receive client ip down. Client not waiting for IP. no FSM context
2022/04/05 11:59:59.783148 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Re-Association received. BSSID 1006.ed3f.1d6e, WLAN DATA2, Slot 1 AP 1006.ed3f.1d60, LSL_Main_1
2022/04/05 11:59:59.783282 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_INIT -> S_CO_ASSOCIATING
2022/04/05 11:59:59.783693 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Association success. AID 4, Roaming = False, WGB = False, 11r = False, 11w = False
2022/04/05 11:59:59.783793 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_ASSOCIATING -> S_CO_L2_AUTH_IN_PROGRESS
2022/04/05 11:59:59.783884 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x31 BSSID: MAC: 1006.ed3f.1d6e capwap IFID: 0x9000000a
2022/04/05 11:59:59.786916 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication initiated. method DOT1X, Policy VLAN 0,AAA override = 0 , NAC = 0
2022/04/05 11:59:59.786931 {wncd_x_R0-0}{1}: [sanet-shim-translate] [16619]: (ERR): a088.69dd.171f wlan_profile Not Found : Device information attributes not populated
2022/04/05 11:59:59.788409 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [16619]: (note): Authentication Success. Resolved Policy bitmap:15 for client a088.69dd.171f
2022/04/05 12:00:00.086676 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f L2 Authentication Key Exchange Start. Resolved VLAN: 22, Audit Session id: C81F4A0A0000016CFAAB36BB
2022/04/05 12:00:00.110310 {wncd_x_R0-0}{1}: [client-keymgmt] [16619]: (note): MAC: a088.69dd.171f EAP Key management successful. AKM:DOT1X Cipher:CCMP WPA Version: WPA2
2022/04/05 12:00:00.110447 {wncd_x_R0-0}{1}: [client-orch-sm] [16619]: (note): MAC: a088.69dd.171f Mobility discovery triggered. Client mode: Flex - Central Switching
2022/04/05 12:00:00.110451 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_L2_AUTH_IN_PROGRESS -> S_CO_MOBILITY_DISCOVERY_IN_PROGRESS
2022/04/05 12:00:00.111136 {wncd_x_R0-0}{1}: [mm-client] [16619]: (note): MAC: a088.69dd.171f Mobility Successful. Roam Type None, Sub Roam Type MM_SUB_ROAM_TYPE_NONE, Client IFID: 0xa000000a, Client Role: Local PoA: 0x9000000a PoP: 0x0
2022/04/05 12:00:00.111288 {wncd_x_R0-0}{1}: [client-auth] [16619]: (note): MAC: a088.69dd.171f ADD MOBILE sent. Client state flags: 0x32 BSSID: MAC: 1006.ed3f.1d6e capwap IFID: 0x9000000a
2022/04/05 12:00:00.111328 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_MOBILITY_DISCOVERY_IN_PROGRESS -> S_CO_DPATH_PLUMB_IN_PROGRESS
2022/04/05 12:00:00.111416 {wncd_x_R0-0}{1}: [dot11] [16619]: (note): MAC: a088.69dd.171f Client datapath entry params - ssid:DATA,slot_id:1 bssid ifid: 0x90000007, radio_ifid: 0x90000002, wlan_ifid: 0xf0400005
2022/04/05 12:00:00.111630 {wncd_x_R0-0}{1}: [dpath_svc] [16619]: (note): MAC: a088.69dd.171f Client datapath entry created for ifid 0xa000000a
2022/04/05 12:00:00.111737 {wncd_x_R0-0}{1}: [client-orch-state] [16619]: (note): MAC: a088.69dd.171f Client state transition: S_CO_DPATH_PLUMB_IN_PROGRESS -> S_CO_IP_LEARN_IN_PROGRESS
9 Replies 9
I assume this issue solve with config ip address with SVI?
Still stuck in ip learn ?
Made no difference, tried removing the SVI for the client VLAN
DHCP for Wifi Client with WLC
THIS IS REMOVE SINCE it WLC9800
1-config the SVI with IP address "same subnet of VLAN use under WLAN" in both Peer
2-remove the secondary <-secondary IP under the SVI
3-config the IP helper in both HSRP Peer
here you must check reachability by
in L3SW
ping DHCP Server IP address Source SVI ip address
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html
two way to config the DHCP external
1-
2-
1. Which setting in the 9800 WLC is this under?
Arshad Safrulla
Can you post the policy profile and Flex profile?
Since you have helper configured directly under the SVI, I would suggest to remove the central dhcp under the policy profile if enabled, you may keep the "ip dhcp required" option enabled once the central dhcp option is removed.
wireless profile policy <Name>
no central association
no central dhcp
no central switching
ipv4 arp-proxy
ipv4 dhcp required
no shutdown
Central DHCP is used only in very unique scenarios such as where the DCHP server is not reachable from the branch, but users must get dhcp from a central server.
JPavonM
In facing a similar issue with some clients under the same site that are stuck on IP Learn when they roam on a C9800 runing 17.3.4. The site has AP4800. Another site with C9120 running 17.3.3 has same issue, but this time clients never pass IP Learn status.
This is happening until next Windows re-auth timer, or after manually bouncing Wi-Fi interface.
My scenario is Flex mode, local forwarding and local DHCP. 2 out of 350 sites impacted by this issue.
I have 2 TAC cases open becuase of this.
Upgrading to 17.4.3c helped it seemed!
Were you able to resolve this issue?
Thanks!
Upgrading helped. Also ensuring proper SVI and VLAN config. DHCP is usually the cause of concern as well
