Cluster of Wireless LAN Controllers
cmanvar700
Shall we make a cluster of Wireless LAN Controllers with deffrent series like
2 x 4000 series and
1 x 2000 series
claeysg
Yes. It's not a cluster but a mobility group.
Just one restriction: you have to use L3 LWAPP as the 2000 does not support L2 LWAPP.
Hi, another question about this subject:
The mobility group could be a Cat3750 with a 4400?
Or could be two stacked 3750s?
Jaime
If you buy a Cat3750 with an integrated controller, in fact it is a Cat3750 where two of the 4GB uplink ports are used internally to connect to the two GB ports of a 4400 controller. The Cat3750 and the controller still need to be configured separetely. Visually, it's one box but in fact it's like two boxes interconnected via a 2Gbps link.
So, yes its possible to create a mobility group between a Cat3750 with integrated controller and a 4400 controller.
Rgds
