CMX 10.2 in DMZ (how do I change Web based Management UI HTTP/HTTPS port
I have a CMX 10.2 located in a DMZ for External splash screen for guest authentication at a remote location using a Cisco 5508 WLC.
after we setup the CMX, the guest can authenticate just fine!!!
but now any body can access the web based management UI, I would like to change the web eased management UI HTTP/HTTPS port so it will not be 80/443 so we can allow guest access but block the web based management UI.
is there a command in the CLI that can help me?
Thank You
0 Replies 0
