Communication problems.
j0han.andersson
Community Member
I just bought a aironet 1200 and a 10 DBI YAGI antenna, problem is I cant communicate with clients connected to my aironet 1200, I can ping via the aironet command line but not with computers behind my ap.
Is it most likely a config error or has someone else got the same problem?
I have a verry simple config now with no security what so ever so that cant be the problem.
I can send my config file if someone is interested in taking a look at it.
Thanks in advance!
Stephen Rodriguez
I would be interested in seeing the config, just so it's easier to see what the settings are. But there is a setting called Public Secured Packet Forwarding under the radio interface. If this is enabled, you will not be able to communicate between clients.
Reference here:
http://cisco.com/application/pdf/en/us/guest/products/ps4076/c2001/ccmigration_09186a0080606a87.pdf
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
