Comparison Between 2800 and 3800 Wireless Access Points
Alex Pfeil
Level 7
Level 7
Would somebody give an example what the difference between a 2800 and 3800 wireless access point? Will the 3800 provide more clients per AP?
2 Accepted Solutions
Hope this link helps 2800 and 3800 AP Tech notes
Both will support same number of clients.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Leo Laohoo
There are only three main difference between the 3800 & 2800.
1. 3800 supports mGIG and 2800 doesn't.
2. 3800e has SMART ports & 2800 doesn't.
3. 3800 is more expensive than the 2800.
Other than that, both 2800 & 3800 are the same internally and functionality-wise.
Leo Laohoo
