Compatibility of APs when upgrading to 8.5 on a 5508 Wireless controller
craig.rogne1
Currently have a 5508 Wireless controller running 8.0.133.0
Purchased a new Aironet that requires version 8.5 or better
Currently have a bunch of AIR-CAP3602I-A-K9 running on 8.0.133.0.  Will there be a problem with these controllers when attempting to update to the 8.5 version on the controller?
JELA
According to the release note : NO
Just check here
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
The 3600 AP will work after upgrade the code.
Leo Laohoo
Last firmware support for the 3600 is 8.5.X.X.
So you are good to upgrade to 8.5.X.X.
WARNING:  Read the Release Notes for 8.5.X.X very, very carefully.  It is NOT POSSIBLE to directly jump from 8.0.X.X without going through an intermediate version like 8.2.16.X.X first.
