Compatibility of wireless AP AIR-SAP1602E-E-K9 in India location.
Pankajrai
We have purchased wireless AP AIR-SAP1602E-E-K9 in India but just noticed that wireless complaince model is -N not -E.Just wanted to know that will it technically work or not
Scott Fella
It will only work if you have the proper country code for -E defined on the WLC. The only thing with using the wrong ap model in a country is breaking the law/regulations in which you can get caught and get in trouble.  Return it and get the correct model.
-Scott
-Scott
We are planning to use it as Standalone and we have already purchased this.Just wanted to understand that wil there be any problem in wireless connectivity on high level.
