compatibility with Catalyst APs
carlos052001
Community Member
I want to gradually deploy my wireless network with Meraki Access Points, and I want to know if there are any complications with deploying and propagating the same SSID with my Catalyst Access Points. What points should be considered?
aleabrahao
Meraki Community All-Star
First of all, make sure you don't have any rogue policies enabled. Since you can't configure a mobility group between the WLC and Meraki, this prevents the APs from being detected as a malicious rogue.
Also, pay attention to channels and signal strength to avoid generating interference. This is for the same reason mentioned above (not being able to configure a mobility group between the two).
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
CMR
Ideally change them as a wave, i.e. start in one part of the building and change neighbours next rather than one on the other side of the building. It'll help with devices moving from one of the Meraki APs to the Catalysts and vice versa.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
elwin-berrar
Level 2
Level 2
HI,
also watch DHCP and ARP behavior too, especially if both AP types share the same VLAN.
Seen a few cases where Catalyst kept old ARP entries after roaming, causing short drops before the refresh.
