Compatible Antenna for ir829
SilverHook
Community Member
Is this MobileMark model LTM502AAKKCWHT180​ compatible with ir829?
We are wondering about GPS interference. Using all 5 antennas (2 RP-TNC connectors for Wi-Fi, 2 TNC connectors for cellular and the SMA connector for GPS) housed in this unit. Thank you
Hello @SilverHook
The connector for the Antenna you mentioned use RA RP TNC  whilst for 829 is RP-TNC. Maybe you need an adapter. Honestly never tried  this but I believe is possible.
 Please share with community if you try it and get success.
-If I helped you somehow, please, rate it as useful.-
