Configuration AP 702i capwap with controller 5508
NejehAflouk5529
hi,
i would   to control a capwap 702i with controller 5508, they are located in tow different network.
the ap has join the controller  but when i enable the wlan, no wlan appears.
i'm using flex-connect technology
thank your for event helps.
Sandeep Choudhary
check any AP group are configured on WLC!! if yes then you nee dto add WLAN in the group.
WLAN > Advanced > AP Groups
Dont forget to rate helpful posts
Sandeep Choudhary
