Configuration register is 0x201 (will be 0x102 at next reload) in WLC CT5760 mean ?
what does the below statement mean in a WLC CT5760 sh version output. Please explain.
Raghavendra
Mark Malone
HI
0x201 means it will boot from the first image it finds in flash ,  0x2102  is the default standard and 0x102 is basically the same but does not boot into rom if there's a failure during bootup
http://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html#config-reg-meaning
If that answers your query pls rate the post thanks
