Configure Aironet 2602i access points for stand alone operation
Drewwright888
I have two Cisco Aironet 2602i Access Points currently connected to a wireless controller. I would like to remove these from the controller and reconfigure the access points for stand alone operations. I have not done this before and would appreciate any help or advice you may give.
Thank you
engineerangelo
Hello Drew,
You have to download a standalone firmware and load it to the AP to convert it to autonomous mode. The standalone IOS has k9w7 on its file name while the LWAPP / CAPWAP version has k9w8. If you know how to upgrade a switch IOS of a 3750 switch then this should be no problem to you. It's the same procedure.
Thanks.
c.flavell
This might be easier
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01101110.html
