Configure Cisco ISR 1941W as Wireless Access point
viversector
I am trying to configure a Cisco 1941W to act as a wireless access point for an existing wired network. Interface gi0/1 on the 1941 will connect to a switch that is using the 192.168.115.0/24 range. The 1941 will have the IP 192.168.115.239.
Is anyone able to provide me basic steps that I need to configure the 1941 and the integrated wireless AP? I just need to get the basic config for the 1941 and the web interface running for the wireless AP so I can configure the wireless settings from there.
Thanks!
https://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/wlan.html
https://networklessons.com/uncategorized/cisco-1941w-wireless-configuration-example
these should help you
*****Help out other by using the rating system and marking answered questions as "Answered"*****
viversector
Thanks for those links, I must be doing something wrong, I don't seem to be able to ping 192.168.115.238 and 192.168.115.239 on the 1941 from a computer connected to the switch with an IP of 192.168.115.171.
My configs are below;
CR1941#sh run
Building configuration...
Current configuration : 1568 bytes
! Last configuration change at 11:56:44 UTC Wed Aug 17 2022
! NVRAM config last updated at 11:56:47 UTC Wed Aug 17 2022
version 15.7
service config
hostname CR1941
boot-start-marker
boot-end-marker
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip cef
no ipv6 cef
license udi pid CISCO1941W-N/K9 sn FGL163325DQ
hw-module ism 0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface wlan-ap0
ip address 11.11.11.11 255.255.255.255
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
switchport mode access
no ip address
interface Vlan1
ip address 192.168.115.238 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
ntp server 34.202.215.187
end
The config for the embedded AP is below;
ap#sh run
Current configuration : 2960 bytes
version 12.4
no service pad
hostname ap
enable secret 5 $1$/Jnc$9gCAMcPRLdmY2b9cb.uTY1
no aaa new-model
dot11 syslog
username cisco privilege 15 secret 5 $1$7N8S$/O8Qu20ToS2LaTpsBZ/uZ1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.115.239 255.255.255.0
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
privilege level 15
login local
line vty 0 4
login local
cns dhcp
end
