Configure MESH on WLC4402 with LAP1242
I have a Cisco 4402 WLC running version 4.2.112.0 controlling 20+ AIR-LAP1242AG-E-K9 access points running IOS 12.4 (10b). I'm trying to setup an additional AP as MESH. When I try to change the mode from local to bridge, on what will be the rootAP, I get a message stating that bridging is not support on this unit. What do I need to get this working?
Any help or pointers would be greatly appreciated.
Best Regards
Justin
Amjad Abdullah
Hi Justin,
If I remember correctly, with WLC code versoin 4.x there was a specific image to support mesh. If you go to cisco download page for the WLC code 4.x for your controller's model, you'll find a normal image and a mesh image. MESH image supports bridge mode.
Amjad
Rating useful replies is more useful than saying "Thank you"
Scott Fella
Just to add to Amjad's post, you might be better off to just upgrade to the latest v7.0.x code. Since with the later codes, mesh is built in and also more if a stable code. The link below shows you the upgrade path.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_240_0.html#wp784219
Here is a link in what AP is supported in what WLC version also
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp98682
-Scott
Amjad/Scott
Thanks for your replies. I tried to download but I don't seem to be able. Do I need a support contract to be able to get these files?
Justin
Yes you do need a support contract to download the software. So either way, either you use a mesh code just for the v4.2 or you use a v7.0.x that can support multiple modes on an access point including mesh, you will need a support contract for the 4400 to be able to download the code you want.
-Scott
